Just Curious - has anyone played around with HS4 in a docker containter?
HS4 in Docker?
Guest
I think you can try this if you use linux https://github.com/marthoc/docker-homeseer ssorry just read you searched for hs4... https://hub.docker.com/r/e1ite/docker-homeseer4
I happened to make one based on marthocs yesterday if folks want me to publish it?
It has 4.0.4.0 in it and the right mono build.
Meh will push it now for any that want it https://hub.docker.com/r/scyto/docker-homeseer4beta
If i end up using HS i will like do multiarch build, maybe even a windows container too!
- Likes 1
I've also been running in docker (only place I ever ran it) - I did run into some bizarre implementation where homeseer tries to launch a browser at first install to register the license and such, and until you fill that out the root page just returns an error with no explanation. Hopefully they realize this isn't the right solution for headless servers and instead they do a redirect from `/` to `/register.html` when that step is required. In the meantime you can browse to the registration page manually.
Originally posted by scyto View PostIf i end up using HS i will like do multiarch build, maybe even a windows container too!
https://forums.homeseer.com/forum/ho...82#post1119482
Originally posted by HTGeek View Post
You may want to check my post on the attempts to run HS3 in a windows container. Bottom line, didn't work. From the looks of HS4 it will have the same issues.
Guest
Yes but you’ll have some limitations after. I do not remember them i am on linux now. A search on the forum may be what you need
I got docker installed in VMware photon.. I have no clue wth im doing!!! LOL.. did it just because... playing around...
man I need to learn this stuff...
Hi all,
Hopefully my experience can help others;
Please keep in mind I'm brand new to both HS4 Pro, Linux, Ubuntu, and Docker. I have got this working just today. I am yet to stress test at all, but it's running, and that's a plus for me. Note: I installed HS4 from nothing (not an upgrade from HS3)
Let's start;
I'm running Ubuntu 20.04
Code:> lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 20.04 LTS Release: 20.04 Codename: focal
https://www.digitalocean.com/communi...n-ubuntu-20-04
Then I did some searching around homeseer and docker, and found a couple of images on DockerHub;
I found that running some of these docker images wasn't intuitive for me, and ended up re-installing a clean HS4Pro when launched, but I needed to launch my already installed copy of HS4Pro, including my licence, etc.
Eventually found e1ite's docker image on DockerHub;
The best thing here is that the instructions are very helpful.
I then used what I just learnt from docker to pull e1ite's image down.
I looked at the instructions on creating a docker container from his page;
Code:docker run -d \ --name homeseer \ -v /opt/homeseer:/HomeSeer \ -v /etc/localtime:/etc/localtime:ro \ -p 80:80 \ -p 10200:10200 \ -p 10300:10300 \ -p 10401:10401 \ --device /dev/ttyUSB0 \ e1ite/docker-homeseer4:latest
Code:-v /opt/homeseer:/HomeSeer
Code:-v /home/maven/HomeSeer:/HomeSeer \
Code:-p 8080:80 \
Code:--device /dev/ttyUSB0 \
Code:docker run -d \ --name homeseer \ -v /home/maven/HomeSeer:/HomeSeer \ -v /etc/localtime:/etc/localtime:ro \ -p 8080:80 \ -p 10200:10200 \ -p 10300:10300 \ -p 10401:10401 \ e1ite/docker-homeseer4:latest
Code:user@server:~$ docker ps CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES f3248e991998 e1ite/docker-homeseer4:latest "/init" 23 minutes ago Up 23 minutes 0.0.0.0:10200->10200/tcp, 0.0.0.0:10300->10300/tcp, 0.0.0.0:10401->10401/tcp, 0.0.0.0:8080->80/tcp homeseer
SUCCESS! I'm extremely happy considering my complete lack of experience here. Can't wait to dig my teeth into HS4Pro.
- Likes 3
Originally posted by mavenmills View PostHi all,
Hopefully my experience can help others; Please keep in mind I'm brand new to both HS4 Pro, Linux, Ubuntu, and Docker. I have got this working just today. I am yet to stress test at all, but it's running, and that's a plus for me. Note: I installed HS4 from nothing (not an upgrade from HS3)
....my final run command was;
I already had a little experience recently with docker as I used it to get deCONZ running. I am on Debian 10. Already had played with HS4 for a while now but got it thoroughly messed up (another story) and since I no longer had a good working version of HS3 due to all the work I did in HS4, I started over with a fresh HS3 on Debian 9. Spent this past week building it back up (~30 devices & about 50 events) and then this morning I copied it over to Debian 10 where I installed HS 4.0.6.0 on top of it. It came up easily. Then I tried your above command to dockerize it, which worked but... HSTouch could not contact it. The error referenced IP 172.17.0.4 and I though wtf? So, I reviewed the homeseer startup log where I saw that homeseer said it's local IP was 172.17.0.4. Hmm... that could be a problem! After some googling which gave me clues but did not give me a definitive answer, I happened to look at my deconz run command and it uses --net. I read up on that and and changed my homeseer docker run command to:
Code:docker run -d \ --name homeseer \ --network=host \ --restart unless-stopped \ -v /etc/localtime:/etc/localtime:ro \ -v /usr/local/HomeSeer:/HomeSeer \ --device /dev/ttyUSB0 \ e1ite/docker-homeseer4:latest
Hope this helps everyone!
-Daniel
BTW, if someone can tell me how the hell I can update my very old signature below, I'd appreciate it!
V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V VHS4 Pro Edition 4.2.5.0 running on Lenovo ThinkCenter & Debian Linux
Plugins: Z-Wave (via Nortek USB stick
Home Assistant 2021.10.6 running on HA "Blue" ODROID-N2
Add-ons: Android Debug Bridge, Duck DNS, ESPHome, File Editor, Glances, HA Google Drive Backup, InfluxDB, Log Viewer, MariaDB, Mosquitto broker, NGINX SSL Proxy, Node-RED, Portainer, SSH & Web Terminal, Samba, TasmoAdmin, UniFi Controller, Visual Studio Code, WireGuard, Zigbee2mqtt, Z-Wave JS to MQTT
Integrations: AccuWeather, Alexa Media Player, Glances, Google Nest, HACS, HomeSeer, Insteon, IPP, Life360, Local IP, Logitech Harmony Hub, Mobile App, MQTT, My Garage, OpenWeather, Spotify, Tuya Local. Ubiquiti UniFi, Z-Wave JS
Insteon: 2413S Dual Band PLM
Zigbee: zzh! CC2652R Rev A
Z-Wave: RaZberry daughtercard on RPi 1B via ser2net
