Can't add more than 4 states for device
  • Can't add more than 4 states for device
    Condition:
    I needed to add a 5th device status to a virtual device managing security system modes. I already have 4 values defined for the device.
    Failure:
    When pressing the NEW SINGLE VALUE button, nothing happens (see image attached).
    Observation:
    Mysteriously, I can add a NEW RANGE VALUE.
    I tried both Safari and Edge browsers.
    HS4 Pro Edition 4.0.5.0 (Windows)
    I changed the values of the items 1-3 to 2-4, then I tried again and pressed NEW SINGLE VALUE. Then a new 5th item got added with value 1. I could now add more values.
    There must be some bug that blocked adding single values for some reason.
    I still have the old configuration device JSON file and can reproduce this error.
      This page is work in progress.
      Please use the deviceutility page
      John
        OK thanks, I got around this bug. If you need the JSON at some point, let me know
          Please share the JSON, so I can see if that will make the things easier as using the deviceutility page.
          John
            Here it is:
            "K63":
            {"addDisplayData":null,"address":null,"attention":null,"code ":null,"relationship":0,"assDevs":null,"buttons":null,"canDi m":false,"devTypeString":null,"devType":{"Device_API":0,"Dev ice_API_Description":"No API","Device_Type":0,"Device_Type_Description":"Type 0","Device_SubType":0,"Device_SubType_Description":""},"devS tring":null,"devValue":0.0,"image":"images\\Devices\\Image-Not-Selected.png","imageLarge":"images\\Devices\\Image-Not-Selected.png","interface":null,"interfaceInstance":null,"las tChange":"2017-08-14T01:21:34.6338298-07:00","location":"Main","location2":"Main","misc":256,"name ":"Security Mode","newDevString":null,"newDevValue":0.0,"plugExtraData": "AAEAAAD/////AQAAAAAAAAAMAgAAAEJIb21lU2VlckFQSSwgVmVyc2lvbj0xLjAuMi4xLCBD dWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPW51bGwFAQAAACpIb21l U2VlckFQSS5QbHVnRXh0cmFEYXRhK2Nsc1BsdWdFeHRyYURhdGECAAAABE5j b2wFVU5jb2wDAx1TeXN0ZW0uQ29sbGVjdGlvbnMuU29ydGVkTGlzdBxTeXN0 ZW0uQ29sbGVjdGlvbnMuQXJyYXlMaXN0AgAAAAoKCw==","ref":63,"scal eText":null,"sortCode":null,"sortString":"Off\r\n\r\n","sort Time":"2017081401213463","statusSupport":false,"userNote":nu ll,"vgPairs":"AAEAAAD/////AQAAAAAAAAAMAgAAAEBTY2hlZHVsZXIsIFZlcnNpb249My4wLjAuMCwgQ3Vs dHVyZT1uZXV0cmFsLCBQdWJsaWNLZXlUb2tlbj1udWxsBQEAAAAcU2NoZWR1 bGVyLkNsYXNzZXMuY2xzVkdQYWlycwIAAAAIbXZhckxpc3QOUGFpcnNQcm90 ZWN0ZWQDABxTeXN0ZW0uQ29sbGVjdGlvbnMuSGFzaHRhYmxlAQIAAAAJAwAA AAAEAwAAABxTeXN0ZW0uQ29sbGVjdGlvbnMuSGFzaHRhYmxlBwAAAApMb2Fk RmFjdG9yB1ZlcnNpb24IQ29tcGFyZXIQSGFzaENvZGVQcm92aWRlcghIYXNo U2l6ZQRLZXlzBlZhbHVlcwAAAwMABQULCBxTeXN0ZW0uQ29sbGVjdGlvbnMu SUNvbXBhcmVyJFN5c3RlbS5Db2xsZWN0aW9ucy5JSGFzaENvZGVQcm92aWRl cgjsUTg/BgAAAAoKAwAAAAkEAAAACQUAAAAQBAAAAAIAAAAGBgAAAAExBgcAAAABMBAF AAAAAgAAAAkIAAAACQkAAAAMCgAAAEJIb21lU2VlckFQSSwgVmVyc2lvbj0x LjAuMi4xLCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPW51bGwF CAAAABxIb21lU2VlckFQSS5WU1ZHUGFpcnMrVkdQYWlyCQAAAAhQYWlyVHlw ZQttdmFyR3JhcGhpYwltdmFyVmFsdWUKUmFuZ2VTdGFydAhSYW5nZUVuZAVM YWJlbAVSYW5nZRFIYXNBZGRpdGlvbmFsRGF0YRJtdmFyUGFpclByb3RlY3Rp b24EAQAAAAEEAAAiSG9tZVNlZXJBUEkuVlNWR1BhaXJzK1ZTVkdQYWlyVHlw ZQoAAAAGBgYqSG9tZVNlZXJBUEkuQ0FQSStDQVBJQ29udHJvbCtjbHNWYWx1 ZVJhbmdlCgAAAAEICgAAAAX1////IkhvbWVTZWVyQVBJLlZTVkdQYWlycytWU1ZHUGFpclR5cGUBAAAAB3ZhbHVl X18ACAoAAAACAAAABgwAAAAhaW1hZ2VzL0hvbWVTZWVyL3N0YXR1cy9sb2Nr ZWQuZ2lmAAAAAAAAAAAAAAAAAADwPwAAAAAAAABACgoAAAAAAAEJAAAACAAA AAHz////9f///wEAAAAGDgAAACNpbWFnZXMvSG9tZVNlZXIvc3RhdHVzL3VubG9ja2VkLmdpZ gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAoKAAAAAAAL","vsPairs":"AAEA AAD/////AQAAAAAAAAAMAgAAAEBTY2hlZHVsZXIsIFZlcnNpb249My4wLjAuMCwgQ3Vs dHVyZT1uZXV0cmFsLCBQdWJsaWNLZXlUb2tlbj1udWxsDAMAAABJU3lzdGVt LCBWZXJzaW9uPTQuMC4wLjAsIEN1bHR1cmU9bmV1dHJhbCwgUHVibGljS2V5 VG9rZW49Yjc3YTVjNTYxOTM0ZTA4OQUBAAAAHFNjaGVkdWxlci5DbGFzc2Vz LmNsc1ZTUGFpcnMCAAAACG12YXJMaXN0DlBhaXJzUHJvdGVjdGVkBAAwU3lz dGVtLkNvbGxlY3Rpb25zLlNwZWNpYWxpemVkLk9yZGVyZWREaWN0aW9uYXJ5 AwAAAAECAAAACQQAAAAABQQAAAAwU3lzdGVtLkNvbGxlY3Rpb25zLlNwZWNp YWxpemVkLk9yZGVyZWREaWN0aW9uYXJ5BAAAAAtLZXlDb21wYXJlcghSZWFk T25seQ9Jbml0aWFsQ2FwYWNpdHkJQXJyYXlMaXN0AwAABSRTeXN0ZW0uQ29s bGVjdGlvbnMuSUVxdWFsaXR5Q29tcGFyZXIBCAMAAAAKAAAAAAAJBQAAABAF AAAAAwAAAAkGAAAACQcAAAAJCAAAAAwJAAAAQkhvbWVTZWVyQVBJLCBWZXJz aW9uPTEuMC4yLjEsIEN1bHR1cmU9bmV1dHJhbCwgUHVibGljS2V5VG9rZW49 bnVsbAQGAAAAIlN5c3RlbS5Db2xsZWN0aW9ucy5EaWN0aW9uYXJ5RW50cnkC AAAABF9rZXkGX3ZhbHVlAgIGCgAAAAEwCQsAAAABBwAAAAYAAAAGDAAAAAEx CQ0AAAABCAAAAAYAAAAGDgAAAAEyCQ8AAAAFCwAAABxIb21lU2VlckFQSS5W U1ZHUGFpcnMrVlNQYWlyFQAAAAhQYWlyVHlwZQptdmFyU3RhdHVzCW12YXJW YWx1ZRVtdmFyUGFpclN0YXR1c0NvbnRyb2wObXZhclBhaXJSZW5kZXITUGFp ckJ1dHRvbkltYWdlVHlwZQ9QYWlyQnV0dG9uSW1hZ2UObXZhclN0cmluZ0xp c3QPUmVuZGVyX0xvY2F0aW9uClJhbmdlU3RhcnQIUmFuZ2VFbmQRUmFuZ2VT dGF0dXNQcmVmaXgRUmFuZ2VTdGF0dXNTdWZmaXgTUmFuZ2VTdGF0dXNEZWNp bWFscxJSYW5nZVN0YXR1c0Rpdmlzb3INSW5jbHVkZVZhbHVlcwtWYWx1ZU9m ZnNldBFIYXNBZGRpdGlvbmFsRGF0YQhIYXNTY2FsZQtaZXJvUGFkZGluZw5t dmFyQ29udHJvbFVzZQQBAAQEBAEDBAAAAQEAAAAAAAAABCJIb21lU2VlckFQ SS5WU1ZHUGFpcnMrVlNWR1BhaXJUeXBlCQAAAAYeSG9tZVNlZXJBUEkuZVBh aXJTdGF0dXNDb250cm9sCQAAACFIb21lU2VlckFQSS5FbnVtcytDQVBJQ29u dHJvbFR5cGUJAAAAKEhvbWVTZWVyQVBJLkVudW1zK0NBUElDb250cm9sQnV0 dG9uSW1hZ2UJAAAAf1N5c3RlbS5Db2xsZWN0aW9ucy5HZW5lcmljLkxpc3Rg MVtbU3lzdGVtLlN0cmluZywgbXNjb3JsaWIsIFZlcnNpb249NC4wLjAuMCwg Q3VsdHVyZT1uZXV0cmFsLCBQdWJsaWNLZXlUb2tlbj1iNzdhNWM1NjE5MzRl MDg5XV0lSG9tZVNlZXJBUEkuRW51bXMrQ0FQSUNvbnRyb2xMb2NhdGlvbgkA AAAGBggGAQYBAQEbSG9tZVNlZXJBUEkuZVBhaXJDb250cm9sVXNlCQAAAAkA AAAF8P///yJIb21lU2VlckFQSS5WU1ZHUGFpcnMrVlNWR1BhaXJUeXBlAQAAAAd2YWx1Z V9fAAgJAAAAAQAAAAYRAAAAA09mZgAAAAAAAAAABe7///8eSG9tZVNlZXJBUEkuZVBhaXJTdGF0dXNDb250cm9sAQAAAAd2YWx1ZV9fAA gJAAAAAwAAAAXt////IUhvbWVTZWVyQVBJLkVudW1zK0NBUElDb250cm9sVHlwZQEAAAAHdmFsdWVf XwAICQAAAAUAAAAF7P///yhIb21lU2VlckFQSS5FbnVtcytDQVBJQ29udHJvbEJ1dHRvbkltYWdlAQAAA Ad2YWx1ZV9fAAgJAAAAAAAAAAoKBev///8lSG9tZVNlZXJBUEkuRW51bXMrQ0FQSUNvbnRyb2xMb2NhdGlvbgMAAAADUm 93BkNvbHVtbgpDb2x1bW5TcGFuAAAACAgICQAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAGFgAAAAAJFgAAAAAAAAAAAAAAAAAAAAEAAAAAAAAAAA AAAAXp////G0hvbWVTZWVyQVBJLmVQYWlyQ29udHJvbFVzZQEAAAAHdmFsdWVfXwAICQAA AAAAAAABDQAAAAsAAAAB6P////D///8BAAAABhkAAAAFU2xlZXAAAAAAAADwPwHm////7v///wMAAAAB5f///+3///8FAAAAAeT////s////AAAAAAoKAeP////r////AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkWAAAACRYAAAAAAAAAAAAA AAAAAAABAAAAAAAAAAAAAAAB4f///+n///8AAAAAAQ8AAAALAAAAAeD////w////AQAAAAYhAAAAB1NlY3VyZWQAAAAAAAAAQAHe////7v///wMAAAAB3f///+3///8FAAAAAdz////s////AAAAAAoKAdv////r////AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkWAAAACRYAAAAAAAAAAAAA AAAAAAABAAAAAAAAAAAAAAAB2f///+n///8AAAAACw==","scriptName":null,"scriptFunc":null,"stringSelec ted":null,"invalidValue":false,"userAccess":"Any","linkedDev ice":0,"voiceCommand":null,"version":3.2}
