what about the new z-wave plugins for hs4?
z-wave hs4
The current Z-Wave PI is working fine for me in HS4.HS4 Pro Edition 4.2.5.0 running on Lenovo ThinkCenter & Debian Linux
Plugins: Z-Wave (via Nortek USB stick
Home Assistant 2021.10.6 running on HA "Blue" ODROID-N2
Add-ons: Android Debug Bridge, Duck DNS, ESPHome, File Editor, Glances, HA Google Drive Backup, InfluxDB, Log Viewer, MariaDB, Mosquitto broker, NGINX SSL Proxy, Node-RED, Portainer, SSH & Web Terminal, Samba, TasmoAdmin, UniFi Controller, Visual Studio Code, WireGuard, Zigbee2mqtt, Z-Wave JS to MQTT
Integrations: AccuWeather, Alexa Media Player, Glances, Google Nest, HACS, HomeSeer, Insteon, IPP, Life360, Local IP, Logitech Harmony Hub, Mobile App, MQTT, My Garage, OpenWeather, Spotify, Tuya Local. Ubiquiti UniFi, Z-Wave JS
Insteon: 2413S Dual Band PLM
Zigbee: zzh! CC2652R Rev A
Z-Wave: RaZberry daughtercard on RPi 1B via ser2net
Originally posted by rjh View PostWe have a new Z-Wave plugin that is a new HS4 UI over the HS3 plugin. Due to Z-Wave cetrification issues we cannot change the HS3 plugin at this time. But the new UI will make it easier to use.
In fact, I don't see any zwave plug at all (no HS3 or HS4)
Can you please explain?Regards,
Rien du Pre
The Netherlands
Using:
Homeseer PRO latest HS4 BETA on a Raspberry
Plugin's:
RFXCOM, mcsMQTT, Z-Wave
Originally posted by Rien du Pre View PostFound it
I searched on zwave instead of z-wave.
But what about the new HS4 z-wave plugin?
Does the plugin need to be certified? I find that very hard to believe. That would mean it has to be recertified for every bugfix. They are not building something from scratch, there is an SDK available.
Also, all networking stuff is done on the coordinator, not the plugin. The coordinator is certified, nothing else.
Verstuurd vanaf mijn SM-G965F met Tapatalk
Originally posted by kriz83 View PostDoes the plugin need to be certified? I find that very hard to believe. That would mean it has to be recertified for every bugfix. They are not building something from scratch, there is an SDK available.
