Not alle to install HS4 properly on Ubuntu 18.04
    Hello, Im unfortunately not able to get HomeSeer running on my Ubuntu 18.04. When I try to open up http://10.0.0.191:88 I Get no response from server
    Start log:
    tom@wideserver:/opt/HomeSeer$ sudo ./go
    [sudo] password for tom:
    HomeSeer Linux starting...
    11:24:40:0526:[Database]->Opening (Mode=Read Only) up HomeSeer LOG database /opt/HomeSeer/Logs/HomeSeerLog.hsd
    11:24:40:4746:[Startup]->Loading Settings
    11:24:40:5465:[Warning]->HomeSeer was not shut down successfully the previous time it was started.
    11:24:40:6508:[Startup]->Settings Loaded.
    11:24:40:7869:[Startup]->
    11:24:40:7872:[Startup]->*********************************************************** *********************
    11:24:40:7881:[Startup]-> HomeSeer version 4.1.1.0 Edition: HS4 Pro Starting Now
    11:24:40:7883:[Startup]->*********************************************************** *********************
    11:24:40:7885:[Startup]->
    11:24:40:8070:[Startup]->Creating Class Objects...
    11:24:40:8083:[Startup]->COM port classes started.
    11:24:40:8103:[Startup]->Application interface class started.
    11:24:40:8334:[Startup]->Web server class started.
    11:24:40:8344:[Startup]->E-Mail SEND class started.
    11:24:40:8348:[Startup]->E-Mail RECEIVE class started.
    11:24:40:8369:[Startup]->Plug-In Interface class started.
    11:24:40:8380:[Startup]->Local voice recognition class started.
    11:24:40:8395:[Startup]->Loading configuration file ...
    11:24:40:8455:[3]->Unable to load devices config file, trying backup
    11:24:40:8458:[4]->Unable to read devices from normal or backup file!
    11:24:40:8491:[3]->Unable to load event groups config file, trying backup
    11:24:40:8494:[4]->Unable to read event groups from normal or backup file!
    11:24:40:8514:[3]->Unable to load events config file, trying backup
    11:24:40:8516:[4]->Unable to load events from normal or backup file!
    11:24:40:8522:[3]->Unable to load counters config file, trying backup
    11:24:40:8524:[4]->Unable to load counters from normal or backup file!
    11:24:40:8529:[3]->Unable to load timers config file, trying backup
    11:24:40:8531:[4]->Unable to load timers from normal or backup file!
    11:24:41:0394:[Startup]->HomeSeer version is: 4.1.1.0
    11:24:41:0399:[Startup]->Creating Speaker Client Interface Object...
    11:24:41:0420:[Warning]->This version of HomeSeer is not registered and is currently disabled
    11:24:41:0578:[Web Server]->Local IP address is: 10.0.0.191
    11:24:41:0616:[Web Server]->Web Server started on port 88
    11:24:41:0928:[Startup]->Start automation engine...
    11:24:41:0947:[Startup]->Initializing Speaker Client Interface
    11:24:41:1100:[Speech]->Listening for remote speaker connections on port 10401
    11:24:41:1191:[Database]->Opening (Mode=Read/Write) up HomeSeer Energy database /opt/HomeSeer/Data/Energy/Energy.hsd
    11:24:41:2825:[Startup]->Updater services starting...
    11:24:41:2837:[Startup]->Starting Find service...
    11:24:41:2940:[Info]->Remote plug-in API interface started on port 10400
    11:24:41:2943:[Startup]->Checking for available plug-ins
    11:24:41:3021:[Startup]->Initializing Plug-Ins
    11:24:41:3125:[HSTouch Server]->Server started on port 10200
    11:24:41:3207:[Startup]->HStouch server started, waiting for clients to connect.
    11:24:41:3245:[Startup]->Starting Event Scheduler...
    11:24:41:3264:[Startup]->HSSentry is disabled in Setup, sentry will not be started.
    11:24:41:3282:[Info]->Checking device parent child relationships...
    11:24:41:3303:[Info]->No device issues found
    11:24:41:3304:[Startup]->Start up complete.
    You need to go to the registration page and enter you license details. localhost/register.html
      Unfortunately, still not able to connect. Using: http://10.0.0.191:88/register.html
        Try findhomeseer.com
        Eman
          I noticed that you started HomeSeer using sudo. You might try running it directly as root.
            Are you leaving the ssh connection open after starting it?
              I had the same problem, think you need to use standard web port 80. After logging in to HS4 you can chose the port you want.
              Edit settings.ini in config folder. (gWebSvrPort=80)
                Well, the issue was related to Safari not redirecting. Solved used Firefox 😀
