Hello, Im unfortunately not able to get HomeSeer running on my Ubuntu 18.04. When I try to open up http://10.0.0.191:88 I Get no response from server
Start log:
Start log:
tom@wideserver:/opt/HomeSeer$ sudo ./go [sudo] password for tom: HomeSeer Linux starting... 11:24:40:0526:[Database]->Opening (Mode=Read Only) up HomeSeer LOG database /opt/HomeSeer/Logs/HomeSeerLog.hsd 11:24:40:4746:[Startup]->Loading Settings 11:24:40:5465:[Warning]->HomeSeer was not shut down successfully the previous time it was started. 11:24:40:6508:[Startup]->Settings Loaded. 11:24:40:7869:[Startup]-> 11:24:40:7872:[Startup]->*********************************************************** ********************* 11:24:40:7881:[Startup]-> HomeSeer version 4.1.1.0 Edition: HS4 Pro Starting Now 11:24:40:7883:[Startup]->*********************************************************** ********************* 11:24:40:7885:[Startup]-> 11:24:40:8070:[Startup]->Creating Class Objects... 11:24:40:8083:[Startup]->COM port classes started. 11:24:40:8103:[Startup]->Application interface class started. 11:24:40:8334:[Startup]->Web server class started. 11:24:40:8344:[Startup]->E-Mail SEND class started. 11:24:40:8348:[Startup]->E-Mail RECEIVE class started. 11:24:40:8369:[Startup]->Plug-In Interface class started. 11:24:40:8380:[Startup]->Local voice recognition class started. 11:24:40:8395:[Startup]->Loading configuration file ... 11:24:40:8455:[3]->Unable to load devices config file, trying backup 11:24:40:8458:[4]->Unable to read devices from normal or backup file! 11:24:40:8491:[3]->Unable to load event groups config file, trying backup 11:24:40:8494:[4]->Unable to read event groups from normal or backup file! 11:24:40:8514:[3]->Unable to load events config file, trying backup 11:24:40:8516:[4]->Unable to load events from normal or backup file! 11:24:40:8522:[3]->Unable to load counters config file, trying backup 11:24:40:8524:[4]->Unable to load counters from normal or backup file! 11:24:40:8529:[3]->Unable to load timers config file, trying backup 11:24:40:8531:[4]->Unable to load timers from normal or backup file! 11:24:41:0394:[Startup]->HomeSeer version is: 4.1.1.0 11:24:41:0399:[Startup]->Creating Speaker Client Interface Object... 11:24:41:0420:[Warning]->This version of HomeSeer is not registered and is currently disabled 11:24:41:0578:[Web Server]->Local IP address is: 10.0.0.191 11:24:41:0616:[Web Server]->Web Server started on port 88 11:24:41:0928:[Startup]->Start automation engine... 11:24:41:0947:[Startup]->Initializing Speaker Client Interface 11:24:41:1100:[Speech]->Listening for remote speaker connections on port 10401 11:24:41:1191:[Database]->Opening (Mode=Read/Write) up HomeSeer Energy database /opt/HomeSeer/Data/Energy/Energy.hsd 11:24:41:2825:[Startup]->Updater services starting... 11:24:41:2837:[Startup]->Starting Find service... 11:24:41:2940:[Info]->Remote plug-in API interface started on port 10400 11:24:41:2943:[Startup]->Checking for available plug-ins 11:24:41:3021:[Startup]->Initializing Plug-Ins 11:24:41:3125:[HSTouch Server]->Server started on port 10200 11:24:41:3207:[Startup]->HStouch server started, waiting for clients to connect. 11:24:41:3245:[Startup]->Starting Event Scheduler... 11:24:41:3264:[Startup]->HSSentry is disabled in Setup, sentry will not be started. 11:24:41:3282:[Info]->Checking device parent child relationships... 11:24:41:3303:[Info]->No device issues found 11:24:41:3304:[Startup]->Start up complete.
