Hi All,
I'm trying to upgrade server to HS4 on my Ubuntu Server... I've downloaded software, backed up folder, copied over the HS3 folder with HS4, restarted HomeSeer, and then tried to open webpage - this is where I run into issues. The webpage shows the following error:
This page isn’t working 192.168.0.150 sent an invalid response.
ERR_INVALID_HTTP_RESPONSE
I checked /var/log/syslog - and everything looks to be starting correctly. The web server address is shown as it was before:
8 21:47:52 Server mono[1510295]: 09:47:52:1404:[Web Server]->Local IP address is: 192.168.0.150
Jul 8 21:47:52 Server mono[1510295]: 09:47:52:1440:[Web Server]->Web Server started on port 88
The only error I could note that seemed relevent is:
Jul 8 21:50:57 Server mono[1510295]: 09:50:57:5232:[Warning]->Unable to connect to MyHS service, license ID is 0. Please register the system with a valid license.
Which repeats ever few seconds (I of course can't fix since I can't get into the web interface). Anyone have any ideas on this? Thanks in advance,
BTW: http://find.homeseer.com/findhomeseer/ does find my server - but hitting the link gives me the same page as talked about above.
