Does anyone know where the default backup location is for HS4?
HS4 default backup location
Originally posted by dmcentire View PostSo wait, to clarify, you can't put a network path as the default backup path for auto backups?
That seems like the most important point of doing backups, getting them off the local box in case the drive crashes.
And I'm referring to the Windows version, not the mono linux port.
In response to the OP, using default as the backup location in Linux and it's variants (Ubuntu, Raspbian) you can find your backup located in /usr/local/HomeSeer/html/backups. The backup file should be named something like this 7_31_2020-16_3.zip If in doubt a quick search of your drive for zip backup files if using Linux and unsure of your file location like this sudo find / -name "*.zip" will quickly identify its location. If you want to store that backup away from your primary install you could attach a pen drive to your unit and copy over your backup file.
- Likes 1
