I am doing a scratch rebuild on the new HS4 Pro and I am having and issue trying to work though setting up 7 Zwave Light bulbs (Inovelli RGBW)n and a Zwave On/Off smart switch (inovelli Red Switch) They all show up in devices and I have control of colors and temperatures from the devices screen.
After lots of reading on the forums I am trying to use the switch as a scene controller to control all of the lights with TAPS on the switch.
Tap twice and turn all 7 lights to cool white and raise levels to 254 (Work Mode)
Tap 3 times and turn all lights red and lower percentages to 100 (Movie Mode)
I have tried to use events where IF
Basement Den Light switch Central Scene has a value equal to Scene 001 key pressed 2 times
THEN
set devices
Basement Den TV1 Color Control Cold_White Channel to cold white level 254
Basement Den TV2 Color Control Cold_White Channel to cold white level 254
Basement Den BarRoom Color Control Cold_White Channel to cold white level 254
Basement Den BarRoom2 Color Control Cold_White Channel to cold white level 254
Basement Den DeskLight Color Control Cold_White Channel to cold white level 254
Basement Den BarLight Color Control Cold_White Channel to cold white level 254
Basement Den StairLightColor Control Cold_White Channel to cold white level 254
When I double click the switch I see
/13/2020 10:35:08 AM
Legacy-Plugin
Z-Wave
Device: Basement Den Central Scene Set to 2003
7/13/2020 10:35:08 AM
Legacy-Plugin
Z-Wave
Setting device Central Scene to value 2003 Network: CA1BA563 Node: 14 Device Ref: 85
Legacy-Plugin
Z-Wave
Set_New_Level, Parent: Basement Den Den light Switch, Child:Basement Den Central Scene
Legacy-Plugin
Z-Wave
Set_New_Level_Real called for Basement Den Central Scene, Type=COMMAND_CLASS_CENTRAL_SCENE_V2, EndPoint=0
Legacy-Plugin
Z-Wave
Set_New_Level_Real: Initial device is Basement Den Central Scene
Legacy-Plugin
Z-Wave
Payload1 zd is not nothing
Legacy-Plugin
Z-Wave
Payload1: 5B-03-2D-83-02-0F
Legacy-Plugin
Z-Wave
Frame: 5B-03-2D-83-02-0F
Legacy-Plugin/Script
Z-Wave
ApplicationCommandHandler from Network: CA1BA563 Node: 14 HANDLING: COMMAND_CLASS_CENTRAL_SCENE_V2 Frame(7)=3
But to light activity occurs.
Then I read I needed to use the event to trigger a Zwave Scene so I attempted to build a Scene in Zwave plugins using Scene Manager,
I gave it a name and Scene Number and then tried to edit scene devices.
When I click the dropdown box I see
Basement Den Switch
Node 4 Zwave LM01
Node 5 Zwave Fan Speed
Node 6 Zwave Light
These are all legitimate devices but none of my Inovelli bulbs show up in the selection.
Did I do something wrong in my inclusion process or did I miss some configuration step?
They are available in the IF THEN selections under EVENTS and they work in Device manager
Just not in the Zwave Scene Manager?
OR
Am I off on a tangent trying to accomplish this task in the way I am doing it?
Is there a better (more efficient or easier) way to accomplish the desired different lighting functions?
I have been using HS since ver. 1 and in HS2 I had a great system up and running under HS 3 I moved to another home and just sort of fixed what broke but did hardly any configuration or coding remodeling. Moved again last year and have decided to go full bore again (retired) and am trying to dive back in.
Can anyone give me a shove in the right direction?
Configurations
Date/time=7/13/2020 11:02:01 AM Central Daylight Time
Version=HS4 Pro Edition 4.1.1.0 (Windows)
License=Registered
License ID=xxxxxxx
MyHS Subscription=Basic
MyHS Subscription Backup Interval=No Backup
MyHS Subscription Max Cameras=1
In Virtual Machine=No MFG: intel corporation
Antivirus=Windows Defender
OS=Microsoft Windows 10 Pro - Work Station
OS Version=10.0.18363
Uptime=3 Days 17 Hours 7 Minutes 16 Seconds
User/Access=xxxxxxx
Lan IP=10.10.0.150 (HSserver)
Client IP=10.10.0.150 (HSserver)
WAN IP=xxxxxxxxx
Device Count=76
Event Count=2
Last Event Ran=Movie Lights : New Event - 1, Ran at 7/12/2020 5:08:31 PM
# of unique event scripts=0
Connected Speaker Clients=HSSERVER (127.0.0.1)EFAULT
Processor:=Intel64 Family 6 Model 23 Stepping 10 at 2.48 GHz
Modules/Threads=132 Modules, 53 Threads
Available Threads=1023
System Load=159 Processes, 31% Load
Free/Total Memory=1.70 GBytes / 3.90 GBytes (43% free)
Free/Total Virtual Memory=1.52 GBytes / 4.59 GBytes (33% free)
HomeSeer Memory Used=29 Mbytes
Plugin Memory Used=3 EXE Plug-Ins using 21 Mbytes
Plugins Installed=Harmony Hub 4.0.10.0,Zigbee 4.0.4.0,Z-Wave 3.0.2.0
THEN
set devices
Legacy-Plugin
Z-Wave
Legacy-Plugin
Z-Wave
Legacy-Plugin
Z-Wave
Legacy-Plugin
Z-Wave
Legacy-Plugin
Z-Wave
Legacy-Plugin
Z-Wave
Legacy-Plugin
Z-Wave
Legacy-Plugin
Z-Wave
Z-Wave
Basement Den Switch
Node 4 Zwave LM01
Node 6 Zwave Light
OR
Configurations
License=Registered
License ID=xxxxxxx
User/Access=xxxxxxx
WAN IP=xxxxxxxxx
Device Count=76
Event Count=2
