Our exterior lights have an event set to turn them off at 1:45 AM. I woke up this morning and our exterior lights were still on so I did a little digging. Do I have this event setup incorrectly for recovery? I know I've had some confusion in the past if a system/admin initiated shutdown of the system was considered a "Power failure" when HS starts up the next times. For example does HS have the concept of a dirty/clean shutdown and look for a dirty bit at launch to make a choice over whether or not to run power failure recovery?
- Last night Windows initiated a restart at 1:44:02 AM due to Windows Update.
- HS4's log shows it started loading again at 1:47:23 AM. Great timing on this update Windows.... well done. 🏆
- HS4's log shows it was done loading everything and stable at 1:48:50 AM
- HS4's log shows no attempt to run the event which was supposed to run at 1:45 AM
- The event has "Include in Powerfailure Recovery" enabled yet the event itself doesn't show the little airplane icon which normally means advanced features are enabled.
- The 'Enable Advanced Features' block has the square filled in rather than empty or a checkbox.
