EnergyDB filling up log
    Hi all, my log is getting filled up every few seconds with the below entries, looks to be stuck in some loop?
    Any ideas whats causing this?
    2020-07-24 16:19:17 Energy DB Compaction of remaining data completed, rechecking database size...
    2020-07-24 16:19:17 Energy DB SQL statments completed. Modifying database for Ref 466.
    2020-07-24 16:19:17 Energy DB SQL statments completed. Modifying database for Ref 445.
    2020-07-24 16:19:17 Energy DB SQL statments completed. Modifying database for Ref 558.
    2020-07-24 16:19:17 Energy DB SQL statments completed. Modifying database for Ref 268.
    2020-07-24 16:19:16 Energy DB SQL statments completed. Modifying database for Ref 554.
    2020-07-24 16:19:16 Energy Database Generating compaction records.
    2020-07-24 16:19:16 Energy DB Records will be compacted to 20716 minute blocks of data.
    2020-07-24 16:19:16 Energy DB Calculating compact ratio.
    2020-07-24 16:19:16 Energy DB Database is 0.001953125 MB larger than required and will have the data compacted.
    2020-07-24 16:19:09 Energy DB Compaction of remaining data completed, rechecking database size...
    2020-07-24 16:19:09 Energy DB SQL statments completed. Modifying database for Ref 466.
    2020-07-24 16:19:09 Energy DB SQL statments completed. Modifying database for Ref 445.
    2020-07-24 16:19:09 Energy DB SQL statments completed. Modifying database for Ref 558.
    2020-07-24 16:19:09 Energy DB SQL statments completed. Modifying database for Ref 268.
    2020-07-24 16:19:09 Energy DB SQL statments completed. Modifying database for Ref 554.
    2020-07-24 16:19:09 Energy Database Generating compaction records.
    2020-07-24 16:19:09 Energy DB Records will be compacted to 20716 minute blocks of data.
    2020-07-24 16:19:09 Energy DB Calculating compact ratio.
    2020-07-24 16:19:09 Energy DB Database is 0.001953125 MB larger than required and will have the data compacted.
    2020-07-24 16:19:02 Energy DB Compaction of remaining data completed, rechecking database size...
    2020-07-24 16:19:02 Energy DB SQL statments completed. Modifying database for Ref 466.
    2020-07-24 16:19:02 Energy DB SQL statments completed. Modifying database for Ref 445.
    2020-07-24 16:19:01 Energy DB SQL statments completed. Modifying database for Ref 558.
    2020-07-24 16:19:01 Energy DB SQL statments completed. Modifying database for Ref 268.
    2020-07-24 16:19:01 Energy DB SQL statments completed. Modifying database for Ref 554.
    2020-07-24 16:19:01 Energy Database Generating compaction records.
    2020-07-24 16:19:01 Energy DB Records will be compacted to 20716 minute blocks of data.
    2020-07-24 16:19:01 Energy DB Calculating compact ratio.
    2020-07-24 16:19:01 Energy DB Database is 0.001953125 MB larger than required and will have the data compacted.
    2020-07-24 16:18:55 Energy DB Compaction of remaining data completed, rechecking database size...
    2020-07-24 16:18:55 Energy DB SQL statments completed. Modifying database for Ref 466.
    2020-07-24 16:18:55 Energy DB SQL statments completed. Modifying database for Ref 445.
    2020-07-24 16:18:55 Energy DB SQL statments completed. Modifying database for Ref 558.
    2020-07-24 16:18:55 Energy DB SQL statments completed. Modifying database for Ref 268.
    2020-07-24 16:18:54 Energy DB SQL statments completed. Modifying database for Ref 554.
    2020-07-24 16:18:54 Energy Database Generating compaction records.
    2020-07-24 16:18:54 Energy DB Records will be compacted to 20716 minute blocks of data.
    2020-07-24 16:18:54 Energy DB Calculating compact ratio.
    2020-07-24 16:18:54 Energy DB Database is 0.001953125 MB larger than required and will have the data compacted.
    2020-07-24 16:18:48 Energy DB Compaction of remaining data completed, rechecking database size...
    2020-07-24 16:18:48 Energy DB SQL statments completed. Modifying database for Ref 466.
    2020-07-24 16:18:48 Energy DB SQL statments completed. Modifying database for Ref 445.
    2020-07-24 16:18:48 Energy DB SQL statments completed. Modifying database for Ref 558.
    2020-07-24 16:18:47 Energy DB SQL statments completed. Modifying database for Ref 268.
    2020-07-24 16:18:47 Energy DB SQL statments completed. Modifying database for Ref 554.
    2020-07-24 16:18:47 Energy Database Generating compaction records.
    2020-07-24 16:18:47 Energy DB Records will be compacted to 20716 minute blocks of data.
    2020-07-24 16:18:47 Energy DB Calculating compact ratio.
    2020-07-24 16:18:47 Energy DB Database is 0.001953125 MB larger than required and will have the data compacted.
    2020-07-24 16:18:41 0 0.00
    2020-07-24 16:18:40 Energy DB Compaction of remaining data completed, rechecking database size...
    2020-07-24 16:18:40 Energy DB SQL statments completed. Modifying database for Ref 466.
    2020-07-24 16:18:40 Energy DB SQL statments completed. Modifying database for Ref 445.
    2020-07-24 16:18:40 Energy DB SQL statments completed. Modifying database for Ref 558.
    2020-07-24 16:18:40 Energy DB SQL statments completed. Modifying database for Ref 268.
    2020-07-24 16:18:40 Energy DB SQL statments completed. Modifying database for Ref 554.
    2020-07-24 16:18:40 Energy Database Generating compaction records.
    2020-07-24 16:18:40 Energy DB Records will be compacted to 20716 minute blocks of data.
    2020-07-24 16:18:40 Energy DB Calculating compact ratio.
    2020-07-24 16:18:40 Energy DB Database is 0.001953125 MB larger than required and will have the data compacted.
    2020-07-24 16:18:34 Energy DB Compaction of remaining data completed, rechecking database size...
    2020-07-24 16:18:34 Energy DB SQL statments completed. Modifying database for Ref 466.
    2020-07-24 16:18:34 Energy DB SQL statments completed. Modifying database for Ref 445.
    2020-07-24 16:18:34 Energy DB SQL statments completed. Modifying database for Ref 558.
    2020-07-24 16:18:33 Energy DB SQL statments completed. Modifying database for Ref 268.
    2020-07-24 16:18:33 Energy DB SQL statments completed. Modifying database for Ref 554.
    2020-07-24 16:18:33 Energy Database Generating compaction records.
    2020-07-24 16:18:33 Energy DB Records will be compacted to 20716 minute blocks of data.
    2020-07-24 16:18:33 Energy DB Calculating compact ratio.
    2020-07-24 16:18:33 Energy DB Database is 0.001953125 MB larger than required and will have the data compacted.
    2020-07-24 16:18:27 Energy DB Compaction of remaining data completed, rechecking database size...
    2020-07-24 16:18:27 Energy DB SQL statments completed. Modifying database for Ref 466.
    2020-07-24 16:18:27 Energy DB SQL statments completed. Modifying database for Ref 445.
    2020-07-24 16:18:27 Energy DB SQL statments completed. Modifying database for Ref 558.
    2020-07-24 16:18:27 Energy DB SQL statments completed. Modifying database for Ref 268.
    2020-07-24 16:18:26 Energy DB SQL statments completed. Modifying database for Ref 554.
    2020-07-24 16:18:26 Energy Database Generating compaction records.
    2020-07-24 16:18:26 Energy DB Records will be compacted to 20716 minute blocks of data.
    2020-07-24 16:18:26 Energy DB Calculating compact ratio.
    2020-07-24 16:18:26 Energy DB Database is 0.001953125 MB larger than required and will have the data compacted.
    2020-07-24 16:18:20 Energy DB Compaction of remaining data completed, rechecking database size...
    2020-07-24 16:18:20 Energy DB SQL statments completed. Modifying database for Ref 466.
    2020-07-24 16:18:20 Energy DB SQL statments completed. Modifying database for Ref 445.
    2020-07-24 16:18:20 Energy DB SQL statments completed. Modifying database for Ref 558.
    2020-07-24 16:18:20 Energy DB SQL statments completed. Modifying database for Ref 268.
    2020-07-24 16:18:20 Energy DB SQL statments completed. Modifying database for Ref 554.
    2020-07-24 16:18:20 Energy Database Generating compaction records.
    2020-07-24 16:18:20 Energy DB Records will be compacted to 20716 minute blocks of data.
    2020-07-24 16:18:20 Energy DB Calculating compact ratio.
    2020-07-24 16:18:20 Energy DB Database is 0.001953125 MB larger than required and will have the data compacted.
    2020-07-24 16:18:13 Energy DB Compaction of remaining data completed, rechecking database size...
    2020-07-24 16:18:13 Energy DB SQL statments completed. Modifying database for Ref 466.
    2020-07-24 16:18:13 Energy DB SQL statments completed. Modifying database for Ref 445.
    2020-07-24 16:18:13 Energy DB SQL statments completed. Modifying database for Ref 558.
    2020-07-24 16:18:13 Energy DB SQL statments completed. Modifying database for Ref 268.
    2020-07-24 16:18:13 Energy DB SQL statments completed. Modifying database for Ref 554.
    2020-07-24 16:18:13 Energy Database Generating compaction records.
    2020-07-24 16:18:13 Energy DB Records will be compacted to 20716 minute blocks of data.
    2020-07-24 16:18:13 Energy DB Calculating compact ratio.
    anyone?
      Have you disabled logging for Energy Settings?
        Strange, I log energy usage and I don't see one entry that starts with "Energy DB"
          Thanks very much!!!! I've disabled that now, restarted HS and its fixed the issue.
          I still belive there's a bug or something wrong as it shouldn't be running that energyDB process so frequently.
