Battery alert
    Battery alert
    Starting to get a lot of battery powered devices now.
    Any function in HS4 or plugin/script that is easy to set up so it can give me an alert (email) when a device reaches 10% battery life?
    Have a look at SDJ-Health. I think this will help you out.
    Scripts =
    Various
      Thanks enigmatheatre! Just checked, and it looks like it is what I need
        For the sake of the discussion, why couldn't you create an event that triggers on the battery level changing to 10% ?
          SDJ-Health is very good. I also get a weekly report using a VB script that was previously posted on these forms. (Be sure to get rid of the .txt extension and update lines 2 & 3 for your email address). The weekly report is simply an event that runs the script once a week.
          You should be able to create the event when the device changes as well. In the past, I found that 10% was often too late and that the event wasn't reliable (likely because the devices weren't reliable).
