HS4 and Z-Wave
    HS4 and Z-Wave
    What Z-Wave Plug-in should I be using for HS4?
    3.0.2.0 installed with my HS4 upgrade; there's been some inquiries here about a 4.x version but nothing concrete. Why do you ask?
      I believe 3.0.2.4 is latest one..
        I am using version 3.0.2.0. I was expecting to see one designed for HS4. I am asking because my system became unresponsive last night. When I restarted it, the Z-Wave plugin was consuming 40% CPU. I had to restart HS4 again to resolve that issue.
          I would not expect one anytime soon.. They are still trying to keep up with plentiful HS4 bugs.
            No speculation necessary, the official response is here, read through the thread.
            https://forums.homeseer.com/forum/ho...308-z-wave-hs4
              Thank you.
                I still don't see an answer to the question, of those available which is best and why?
                  Windows:
                  3.0.2.0
                  or BETA 3.0.2.4
                  Linux:
                  3.0.2.0
                  BETA 3.0.2.4
                  Linux S2 Support ARM processor (for ARM processor/OS i.e Raspberry)
                  Linux S2 Support X86 processor (for x86 processor/OS)
                  I'm running 3.0.2.0 under Debian 10 which is x64...
                    Originally posted by dbrunt View Post
                    Windows:
                    3.0.2.0
                    or BETA 3.0.2.4
                    Linux:
                    3.0.2.0
                    BETA 3.0.2.4
                    I have seen the suggestion that 3.0.2.0 is newer than 3.0.2.4!
                    However - out of those two, are there any pros or cons to help make the decision?
                      That is equally confusing as it was said that 3.0.2.0 was really equivalent to 3.0.3.0, so does that mean that 3.0.2.4 is really 3.0.3.4?
                      Enabled Plug-Ins:
                        FWIW, I had 3.0.2.4 installed and everything seemed normal until I attempted to move some devices between networks. Exclusion worked but the inclusion process did not - security negotiation failures and many other, unseen before, errors.
                        Reverted to 3.0.2.0, and all devices connected immediately.
                          3.0.2.4 is the newest; the date of the upload is 01 Jul 2020 16:28:56 GMT. 3.0.2.0 is 23 Dec 2019 21:23:05 GMT
                          You're probably thinking of 3.0.2.261 which is indeed older, 08 Apr 2019 14:15:50 GMT
                          Uncertain if this statement is still true. If so, it may hint at a reasoning for the convoluted numbering. I wouldn't hold my breath waiting for an explanation though.
                            That is the S2 version so if you have secure devices then that's the one...
                            ‚Äč
                            What the actual?!? When I make a sarcastic remark or joke it is moderated/deleted.
                            But you specifically go out of your way to label multiple HS4 issues that cause data loss/crash of HS4 to be "grumbles".
                            I can't even begin to put into words how offensive this is.
                              Indeed. Per rjh statement from the link I posted,
                              Any Z-Wave plugin with the version 3.0.2.X has S2 support.
                              If that's accurate (stop laughing), 3.0.2.0 etc. should support S2 as well.
