HS4 V4.1.2.0 Log times off
    Updated this morning to HS4 V4.1.2.0
    Times are way off in the logging. Also my clip and paste of logging from either Firefox or Chrome looks like this now.
    Bottom of log now is days in future which do not exist.
    7/27/2020 12:27:48 PM
    HomeSeer
    Startup
    HomeSeer
    Startup
    HomeSeer version 4.1.2.0 Edition: HS4 Pro Starting Now
    HomeSeer
    Startup
    HomeSeer
    Startup
    HomeSeer
    Startup
    Creating Class Objects...
    HomeSeer
    Startup
    COM port classes started.
    HomeSeer
    Startup
    Application interface class started.
    HomeSeer
    Startup
    Web server class started.
    HomeSeer
    Startup
    E-Mail SEND class started.
    HomeSeer
    Startup
    E-Mail RECEIVE class started.
    HomeSeer
    Startup
    Plug-In Interface class started.
    HomeSeer
    Startup
    Local voice recognition class started.
    HomeSeer
    Startup
    Loading configuration file ...
    7/27/2020 12:27:49 PM
    HomeSeer
    Info
    Loaded 10 Devices.
    HomeSeer
    Info
    Loaded 5 Events.
    HomeSeer
    Warning
    Unable to load counters config file, trying backup
    HomeSeer
    Error
    Unable to load counters from normal or backup file!
    HomeSeer
    Warning
    Unable to load timers config file, trying backup
    HomeSeer
    Error
    Unable to load timers from normal or backup file!
    HomeSeer
    Startup
    HomeSeer version is: 4.1.2.0
    HomeSeer
    Startup
    Creating Speaker Client Interface Object...
    HomeSeer
    Startup
    This version of HomeSeer is registered as a HS4PRO version.
    HomeSeer
    Web Server
    Local IP address is: 192.168.244.172
    HomeSeer
    Web Server
    Web Server started on port 9999
    HomeSeer
    Startup
    Start automation engine...
    Back to the future logs:
    7/31/2020 3:00:00 AM
    HomeSeer
    Info
    Stopping the MyHS Service...
    7/31/2020 10:35:23 PM
    HomeSeer
    ASR
    Speaker Client speech recognition stopped
    Time on Ubuntu server is configured via NTP on the OS. It is correct.
    Top bar of HS4 indicates correct time. It is just the logs which are way off time wise.
    - Pete
    Auto mator
    HS4 Pro - V4.1.3.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.10.0.104
    HS4 Lite -
    Opened up a bug report titled: HS4 V4.1.2.0 Log times off
    Just noticed this:
    Location (Sunrise 5:39 AM Sunset 8:13 PM) Current Time: Monday, July 27, 2020 1:42 PM which is 5 hours ahead of current time.
    Looks to be GMT time in 12 hour format (AM/PM).
    Title bar time is correct:
    8:43:15 AM | 7/27/2020
    Thinking its been like this in the last couple of versions from looking at the logs. Only have looked at the time on top bar and not in the general / setup page.
    - Pete
    Auto mator
    HS4 Lite -
      Just noticed this:
      Pete have you inspected the locales recently in Ubuntu 18.04. I was having strange moments in Armbian so I went in and manually adjusted my locales as per this https://www.google.ie/amp/s/lintut.c...ntu-18-04/amp/ and it seemed to have done the trick.
      The counters and timers issue is an easy enough fix as I imagine you have gathered by now.
        Thank you concordseer
        Here have always been particular about time and never paid attention much to HS time settings in Linux.
        So a quickie review:
        locale
        LANG=en_US.UTF-8
        LANGUAGE=
        LC_CTYPE="en_US.UTF-8"
        LC_NUMERIC="en_US.UTF-8"
        LC_TIME="en_US.UTF-8"
        LC_COLLATE="en_US.UTF-8"
        LC_MONETARY="en_US.UTF-8"
        LC_MESSAGES="en_US.UTF-8"
        LC_PAPER="en_US.UTF-8"
        LC_NAME="en_US.UTF-8"
        LC_ADDRESS="en_US.UTF-8"
        LC_TELEPHONE="en_US.UTF-8"
        LC_MEASUREMENT="en_US.UTF-8"
        LC_IDENTIFICATION="en_US.UTF-8"
        LC_ALL=
        Ahh...just noticed this:
        root@ICS-HS4:~# date
        Mon Jul 27 19:02:02 CDT 2020
        Which is wrong.
        /etc# timedatectl
        Local time: Mon 2020-07-27 19:07:16 CDT
        Universal time: Tue 2020-07-28 00:07:16 UTC
        RTC time: Tue 2020-07-28 00:02:26
        Time zone: America/Chicago (CDT, -0500)
        System clock synchronized: yes
        systemd-timesyncd.service active: yes
        RTC in local TZ: no
        Which is also wrong.
        Doesn't make sense to me that these settings are off as I am using my NTP server on PFSense.
        So shut down HS4. Via command line did the following:
        service ntp stop
        root@ICS-HS4:/etc# ntpdate 192.168.244.129
        27 Jul 11:34:49 ntpdate[3502]: step time server 192.168.244.129 offset -28517.239031 sec
        root@ICS-HS4:/etc# date
        Mon Jul 27 11:35:04 CDT 2020
        Now time is correct.
        Before rebooting going to the NTP server and see it fine:
        ntpq -c clockvar
        associd=0 status=00f0 15 events, clk_unspec,
        device="NMEA GPS Clock",
        timecode="$GPGGA,164417.000,4133.3944,N,08746.9257,W,2,7,1.2 3,237.4,M,-34.0,M,0000,0000*68",
        poll=33705, noreply=0, badformat=0, baddata=0, fudgetime2=407.000,
        stratum=0, refid=GPS, flags=5
        ntpq> lopeers
        remote local st t when poll reach delay offset disp
        oGPS_NMEA(0) 127.0.0.1 0 l 5 16 377 0.000 +0.001 0.232
        0.0.0.0 0.0.0.0 16 p - 64 0 0.000 +0.000 16000.0
        -time1.google.co _14ff:fe9e:d7cf 1 u 26 64 377 38.924 -4.572 4.287
        +time2.google.co _14ff:fe9e:d7cf 1 u 46 64 377 20.564 +2.472 4.852
        *time3.google.co _14ff:fe9e:d7cf 1 u 30 64 377 20.705 +2.473 2.362
        +t2.time.gq1.yah 192.168.244.129 2 u 3 64 377 65.733 +1.819 2.088
        dns.phoenix591. 192.168.244.129 2 u 77h 512 0 34.593 +2.981 15937.5
        -nu.binary.net 192.168.244.129 2 u 38 64 21 23.855 +3.011 12.413
        -time.richiemcin 192.168.244.129 2 u 4 64 377 31.692 +2.388 3.525
        ntpq>
        so now rebooting server with HS4 autostarting to see if it is HS that is changing the time.
        Thinking that may be my issue as I do not have this issue with the two Ubuntu HS3 boxes running on Ubuntu 18.04.
        So here HS4 is not running yet. I put a delay on reboot.
        Mon Jul 27 11:52:13 CDT 2020
        Time is correct.
        Homeseer is running now and time remained correct.
        Mon Jul 27 11:56:46 CDT 2020
        So other than the old "back to the future" log entries I am OK with current log entries.
        - Pete
        Auto mator
        HS4 Lite -
          locale
          LANG=en_US.UTF-8
          LANGUAGE=
          LC_ALL=
          Which is wrong.
          /etc# timedatectl
          RTC in local TZ: no
          service ntp stop
          ntpq -c clockvar
          ntpq> lopeers
          ntpq>
          Time is correct.
          Check out Step 3 in this link. This is the route I took purely for Systemd purposes https://www.google.ie/amp/s/www.digi...-debian-10.amp
          For someone who runs more than one Linux box you might want to experiment with Chrony https://opensource.com/article/18/12/manage-ntp-chrony
          Might be worth while having your own ntp server. Reckon it’s worth a spin.
            Yes today the NTP server on PFSense is running on BSD and using a modded GPS with PPS on one of the 9 serial wires.
            The GPS antenna has a good view of 9 of 11 GPS satellites.
            Have around 8-9 Ubuntu servers running on Intel CPUs. I was running HS3 Lite on a TV Box with Armbian on an S912 chipset. Switched the box over to being a KODI box and went to using an Intel Beelink BT3 Pro now.
            - Pete
            Auto mator
            HS4 Lite -
              Have the rogue time entries in your log disappeared.
              Alternatively you could wire up a good old fashioned grandfather clock to your system. Wind it once a day and you’re good to go 😂
                I am in to antique clocks here. Also have 15 HSTouch screens that typically show a clock screen saver. Overdoing it a bit.
                Have 3 old table clocks which are about 150 years old (well not that old at 150 years) and hallway clock is a regulator pendulum clock that keeps time almost perfectly as I rarely touch it.
                No. Thinking I am just going to delete these logs. Do you know which file the logs resolve in?
                - Pete
                Auto mator
                HS4 Lite -
                  Eventually, "back to the future" will become history...until you find another way to do a time warp!
                    SQLite db:
                    Click image for larger version  Name:	HomeSeerLog.PNG Views:	0 Size:	18.2 KB ID:	1406539
                      Thank you @dbrunt.
                      Its been a while since I have tinkered with the HS4 build and for some odd reason thought that Rich had quit using SQLite for HS. That said I can just edit out the entries with a SQLite editor in Linux. The box isn't doing much these days.
                      Geez for whatever reason here went back to the future....logs are showing I am 5 hours ahead again...doesn't make any sense to me.
                      @ICS-HS4:~# date
                      Tue Jul 28 02:11:36 CDT 2020
                      I do not know what is changing the time other than maybe HS4 is doing this???
                      root@ICS-HS4:~# service ntp stop
                      root@ICS-HS4:~# ntpdate 192.168.244.129
                      27 Jul 21:46:21 ntpdate[2181]: step time server 192.168.244.129 offset -16312.811799 sec
                      root@ICS-HS4:~# service ntp restart
                      Mon Jul 27 21:46:57 CDT 2020
                      This is the second time I have had to do this today. Geez...
                      Ahh...see the hwclock 5 hours ahead.
                      ICS-HS4:~# hwclock --show
                      2020-07-28 02:17:18.495969-0500
                      fixed the hardware clock...
                      root@ICS-HS4:~# hwclock --systohc
                      Mon Jul 27 21:56:18 CDT 2020
                      2020-07-27 21:56:21.931996-0500
                      So basically when I rebooted the computer it would read the time from the hardware clock and never get adjusted to the NTP server time...don't know why...
                      - Pete
                      Auto mator
                      HS4 Lite -
                        Thank you @dbrunt.
                        You're welcome sir!
                        I know how to fix that in Windows but have not had to do it in Linux yet...
                          This is my fault here as I have installed NTP and NTPDate on all of my Ubuntu 18.04 servers. Looks like it is working this morning.
                          - Pete
                          Auto mator
                          HS4 Lite -
                            Sorry Pete. I was admiring your clock and didn’t see your question. Did you find the log files.
                            You can see a lot changed re network settings in Ubuntu 18.04.
                            There’s a load of questionable solutions out there. I just wish when people are posting their solutions they would link them to their sources. Still all good now with you.
                              Still all good now with you?
                              No this morning noticed that I went back to the future with two different time syncs: System time was a day ahead by around 12 hours and HWClock was ahead by 5 hours.
                              Noticed that systemd-timesyncd.service active was off. Started the service and all is well at this time. Will check to make sure it does not get shut off.
                              ICS-HS4:~# timedatectl
                              Local time: Tue 2020-07-28 11:20:12 CDT
                              Universal time: Tue 2020-07-28 16:20:12 UTC
                              RTC time: Tue 2020-07-28 16:20:29
                              RTC in local TZ: no
                              Checked on start up and see that systemd-timesyncd.service is enabled but it appears to shut itself off when rebooting.
                              - Pete
                              Auto mator
                              HS4 Lite -
