HS4 V4.1.2.0 unable to load counters
    7/27/2020 12:27:49 PM
    HomeSeer
    Warning
    Unable to load counters config file, trying backup
    HomeSeer
    Error
    Unable to load counters from normal or backup file!
    HomeSeer
    Warning
    Unable to load timers config file, trying backup
    HomeSeer
    Error
    Unable to load timers from normal or backup file!
    - Pete
    Auto mator
    HS4 Pro - V4.1.3.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.10.0.104
    HS4 Lite -
    Opened a help desk bug report: HS4 V4.1.2.0 unable to load counters
    - Pete
    Auto mator
    HS4 Lite -
      Pete, a bunch of us are getting these errors. I went in and created a dummy timer and counter. That seems to get rid of the errors until they can fix it.
        Thank you cowinger .
        Going baby steps here with HS4 over the last few months while concurrently keeping HS3 running.
        - Pete
        Auto mator
        HS4 Lite -
          Welcome. I understand. I am also taking it one step at a time with HS4. I have HS3 available just in case.
            I switched back to HS3 after I lost all my events in HS4. If you run HS4 makes sure you back up regularly.
              Other than the original error.... anything to worry about here if i don't create the dummy timer/counter?
                It won’t have any material impact on your system not creating them. Everything here running fine on HS4 without them. No doubt that error will disappear with the next release due shortly.
                  Thanks!
