Device/Node management?
    What happened to all the device management (rescan, optimize, etc.)? Also how do you add/remove nodes now? There seems to be no z-wave plugin where you could do all sorts of things like add remove devices and more. With Z-Tool+ not working with HS4, it seems like a step backwards. Not pleased.
    As it is the HS3 plugin it is in exactly the same place. For the network settings, Plugins / Z-Wave / controller management and for a single device click on the device name to get to the device config page then select the z-wave tab at the top of the page then click manage to get to the old UI for the device.
    Scripts =
    Various
      I found and had to install the plug in. Resolved as is my Z-Tool+ issue.
