Nortec HUSBZB-1 Won't Initialize
    I have loaded the driver per these instructions.
    https://helpdesk.homeseer.com/articl...e-driver-setup
    I can add an interface and select the port. When I add it, as a Z-Wave.me UZB, it tries to initialize but never does.
    How do we get it to initialize? thanks
    Zigbee/Z-Wave interfaces and COM ports got somehow mixed up?
      Which COM ports showed up?
        It shows up on COM4.
          HUSBZB-1 generally appears as two adjacent ports. The lower numbered one is the Z-Wave and the higher one Zigbee.
          You do need to run the add driver procedure for each individually.
          * in theory -- I haven't actually connected to it under Windows 10!
            More info: to determine which port is which,
            In device manager, select one of the ports, right click & select Properties
            Go to Details tab, select property 'Bus reported device description'
            Value will be 'HubZ Z-Wave Com Port' or 'HubZ ZigBee Com Port'.
              zwolfpack Thanks for the reply. I got the nortec z-wave to initialize but not the nortec zigbee. They were on com4 and com5 respectively. So I will have to look at it another day.
                Ok, new issue. I got the z-wave part of the controller to initialize but when I tried to transfer info from the current z-wave controller to the nortec z-wave section of the stick it said the controller is unable to enter the Learn mode.
                How do I get past this one? TIA
                  What procedure are you following?
                  I don't know what 'learn mode' is. I was able to transfer node data to a HUSBZB-1 using the restore function of the Z-Wave plugin.
                    I am obviously doing it wrong. Could you give a quick list of steps based on what you said above? Thanks
                      Backup existing interface
                      https://helpdesk.homeseer.com/articl...wave-interface
                      Restore to new interface
                        I didn't find those. Must have searched for the wrong thing. That will work great. Thanks again.
