Really Annoying Thing Happening...
    So, this has been going on for a while and being that I can usually suss these things for myself I've not asked but I've reached a breaking point with this one.
    Basically, seemingly at random, my hallway lights switch off all by themselves and al I can see in the log is this message:
    "Event Trigger "Delayed Actions MCO2 Bt1 Hall Lights (Delayed Action)"
    I cannot locate a delayed action, anywhere.
    I've tried and tried for months to track this down so the question is really simple, how the blazes do I find out what's doing this?
    K.
    Check out Jon00's Event Viewer...it will allow you to perform a global search of all your events in order to find the delayed action.
      you can also sort by 'referencing device' search for 'Hall Lights' and you'll see all events for that device.
      Excuse the HS3 example I've not yet upgraded to HS4
Name:	ref device.JPG
      HS4 Pro on Shuttle NC10U, Win10; Z-NET
      Number of Devices: 1005
      Number of Events: 293
      Plug-Ins: BLLock, DirecTv, EasyTrigger, Honeywell WiFi Thermostat, Marquis monoprice Amp, MeiHarmonyHub, PHLocation2, Pushover 3P, UltraM1G3, rnbWeather, Worx Landroid, Z-Wave
      External applications: Homebridge-homeseer, Geofency, EgiGeoZone.
        I don't think HS4 has that feature.
          There is a way to access HS3 webpages from HS4, but you may not need to do so since search appears to be universal.
          https://forums.homeseer.com/forum/ho...23#post1403723
            The HS4 search box will return a list of all devces and events matching the search criteria. That should help you find it.
              K.
              kwatt
              A delayed action is removed by HS once it has executed. You probably have an event that is triggering an action "after waiting xx hours/minutes/seconds". Indeed the search action described earlier is what you could do. And if you find many events using the MCO2 Bt1 Hall Lights, focus on the ones that have this delay option?
              Wim
              -- Wim
                Brilliant, thanks guys that should help me track it down as it's been driving me nuts.
                K.
                  If those methods don’t work I’d call Ghost Busters!! πŸ˜‚πŸ˜‚πŸ˜‚
