So after upgrading to HS4 and dealing with a couple of interesting quirks, I now find that when i restart or cycle on/off my SEL it no longer automatically starts HomeSeer. I have to putty to ./go to start HS. So thought I would start this new topic.
ConcordeSeer - output of
systemctl list-units --type=service -
homeseer@hometrollerSEL:~$ systemctl list-units --type=service
UNIT LOAD ACTIVE SUB DESCRIPTION
accounts-daemon.service loaded active running Accounts Service
acpid.service loaded active running ACPI event daemon
apparmor.service loaded active exited AppArmor initialization
apport.service loaded active exited LSB: automatic crash repor
avahi-daemon.service loaded active running Avahi mDNS/DNS-SD Stack
binfmt-support.service loaded active exited Enable support for additio
bluetooth.service loaded active running Bluetooth service
console-setup.service loaded active exited Set console font and keyma
cron.service loaded active running Regular background program
cups.service loaded active running CUPS Scheduler
dbus.service loaded active running D-Bus System Message Bus
getty@tty1.service loaded active running Getty on tty1
grub-common.service loaded active exited LSB: Record successful boo
irqbalance.service loaded active running irqbalance daemon
kerneloops.service loaded active running Tool to automatically coll
keyboard-setup.service loaded active exited Set the console keyboard l
kmod-static-nodes.service loaded active exited Create list of required st
lightdm.service loaded active running Light Display Manager
● lighttpd.service loaded failed failed Lighttpd Daemon
ModemManager.service loaded active running Modem Manager
networkd-dispatcher.service loaded active running Dispatcher daemon for syst
networking.service loaded active exited Raise network interfaces
NetworkManager-wait-online.service loaded active exited Network Manager Wait
NetworkManager.service loaded active running Network Manager
polkit.service loaded active running Authorization Manager
● rc-local.service loaded failed failed /etc/rc.local Compatibilit
resolvconf.service loaded active exited Nameserver information man
rsyslog.service loaded active running System Logging Service
rtkit-daemon.service loaded active running RealtimeKit Scheduling Pol
setvtrgb.service loaded active exited Set console scheme
snapd.apparmor.service loaded active exited Load AppArmor profiles man
snapd.seeded.service loaded active exited Wait until snapd is fully
ssh.service loaded active running OpenBSD Secure Shell serve
systemd-journal-flush.service loaded active exited Flush Journal to Persisten
systemd-journald.service loaded active running Journal Service
systemd-logind.service loaded active running Login Service
systemd-modules-load.service loaded active exited Load Kernel Modules
systemd-random-seed.service loaded active exited Load/Save Random Seed
systemd-remount-fs.service loaded active exited Remount Root and Kernel Fi
systemd-resolved.service loaded active running Network Name Resolution
systemd-sysctl.service loaded active exited Apply Kernel Variables
systemd-timesyncd.service loaded active running Network Time Synchronizati
systemd-tmpfiles-setup-dev.service loaded active exited Create Static Device
systemd-tmpfiles-setup.service loaded active exited Create Volatile Files and
systemd-udev-trigger.service loaded active exited udev Coldplug all Devices
systemd-udevd.service loaded active running udev Kernel Device Manager
systemd-update-utmp.service loaded active exited Update UTMP about System B
systemd-user-sessions.service loaded active exited Permit User Sessions
thermald.service loaded active running Thermal Daemon Service
udisks2.service loaded active running Disk Manager
ufw.service loaded active exited Uncomplicated firewall
unattended-upgrades.service loaded active running Unattended Upgrades Shutdo
upower.service loaded active running Daemon for power managemen
user@1000.service loaded active running User Manager for UID 1000
user@107.service loaded active running User Manager for UID 107
whoopsie.service loaded active running crash report submission da
wpa_supplicant.service loaded active running WPA supplicant
xrdp-sesman.service loaded active running xrdp session manager
xrdp.service loaded active running xrdp daemon
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
59 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use 'systemctl list-unit-files'.
lines 45-67/67 (END)
