This constantly occurs for two plug-ins. Netcam for HS3 since the HS4 version doesn't work at all for me. Also SDJ-Health does the same thing. I can disable and re-enable the plug-ins and then they switch to OK and work properly but if HS restarts or I update another PI, I'm bound to see the same warning. Anybody else? Using 4.1.3.0
INFO: Plugin start is pending
I'm on 4.1.3.0 and have not seen this behavior. I do have a bit of a workaround: Jon00 has a plugin that will allow you to enable/disable other plugins. You could use that to reset yours while you investigate further or wait for an HS4 update.HS4 Pro on Shuttle NC10U, Win10; Z-NET
Number of Devices: 1005
Number of Events: 293
Plug-Ins: BLLock, DirecTv, EasyTrigger, Honeywell WiFi Thermostat, Marquis monoprice Amp, MeiHarmonyHub, PHLocation2, Pushover 3P, UltraM1G3, rnbWeather, Worx Landroid, Z-Wave
External applications: Homebridge-homeseer, Geofency, EgiGeoZone.
Originally posted by racerfern View PostWindows 10. HS4 v4.1.3
It's happened since the release and also with a few betas prior to release. It used to happen with Jowihue and PhlipsHue but now it's just SDJ-Health and Netcam.
Do you see anything in the log for SDJ-Health?
Steve
I "think" SDJ is running but Netcam is definitely not running. I haven't had to touch SDJ in over a year so I'll need to confirm. However Netcam just gives a spinning wheel when clicking on any of the sub pages.
I'll restart and see if SDJ complains the way Netcam does but I'm 99% sure SDJ has no errors and it's fine.
Originally posted by racerfern View PostI just restarted and confirmed that SDJ-Health starts and runs without error even though it start is pending. However Netcam only allows access to the help submenu. If I disable and re-enable then it will say OK and I can use the other submenus of Netcam.
I just disabled then uninstalled Netcam meant for HS3. When I went to add a Netcam PI there was a check mark next to the HS4 version even though that was not installed anyway. So I installed it but can't seem to make progress with it. One thing at a time, are others using the Netcam HS4 version without issues?
I think the check mark just indicates that it had been installed at one time or another. I have a couple that show like that...HS4 Pro Edition 4.2.5.0 running on Lenovo ThinkCenter & Debian Linux
Plugins: Z-Wave (via Nortek USB stick
Home Assistant 2021.10.6 running on HA "Blue" ODROID-N2
Add-ons: Android Debug Bridge, Duck DNS, ESPHome, File Editor, Glances, HA Google Drive Backup, InfluxDB, Log Viewer, MariaDB, Mosquitto broker, NGINX SSL Proxy, Node-RED, Portainer, SSH & Web Terminal, Samba, TasmoAdmin, UniFi Controller, Visual Studio Code, WireGuard, Zigbee2mqtt, Z-Wave JS to MQTT
Integrations: AccuWeather, Alexa Media Player, Glances, Google Nest, HACS, HomeSeer, Insteon, IPP, Life360, Local IP, Logitech Harmony Hub, Mobile App, MQTT, My Garage, OpenWeather, Spotify, Tuya Local. Ubiquiti UniFi, Z-Wave JS
Insteon: 2413S Dual Band PLM
Zigbee: zzh! CC2652R Rev A
Z-Wave: RaZberry daughtercard on RPi 1B via ser2net
Originally posted by racerfern View PostThe problem is if HS4 restarts due to a pc restart, I'll never know until I check it. That's not home automation, that's extra work.
Jim
Originally posted by racerfern View PostI just disabled then uninstalled Netcam meant for HS3. When I went to add a Netcam PI there was a check mark next to the HS4 version even though that was not installed anyway. So I installed it but can't seem to make progress with it. One thing at a time, are others using the Netcam HS4 version without issues?
Jim
