4.1.5.0 did not got catch restarting Hs4
    #16
    I will see if this is a new debug message that was left in this build.
      #17
      Also 4.1.5.0 is throwing some debug log for every 5 seconds. Removed this version.
      Same here with Jowihue PI.
      JYA
        #18
        Originally posted by racerfern View Post
        AFAIK, these are all official releases. There's nothing to indicate the latest release was a beta. Then again with the number of issues remaining they're all betas in my book.
        Agree .
          #19
          Some developers requested some debug logging and we did not realize it would flood the log. It will be removed in the next update.
            #20
            Thanks !!
            can I ask if you test new releases with all plugins? Or do some kind of test before posting?
            I think it is best, to always install the version that came out before the actual release.
              #21
              running 4.1.10 ( will upgrade again tonite ) and it is still flooding my logs
              Geary
              Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
                #22
                Hi Geary,
                From what you posted, it doesn't look like any debug info, that's a device reporting its power usage. Depending on the device you can set the frequency of the reporting or even disable it. I had a couple Zooz modules that reported all the time and filled my log - it got to be pretty annoying!
                Dan-O
                HomeSeer contributor since summer 1999, yes 1999!
                  #23
                  yes you need to go on the z-wave tab of the root device.
                  Look at the pictures, here I have set mine to autoreport every 65460 secs , which is almost ''never'' ( 1091 minutes; 18 hours). Maybe you can set this to 0, never tried.
                  Maybe you will have to play with the setting at the very end of the page ( see 3rd pictures) That depends of your model. You will need to check the manual of your device for this
