How do I delete a camera in HS4. I added a couple that no longer work and I want to get rid of them.
Delete Camera is HS4
Originally posted by donstephens View PostDid anyone figure this out?
[Manual Cameras] and delete the cameras you want to remove.-Rupp
Originally posted by donstephens View PostHS4. So the web interface on the setup page has no way to delete a camera? I'll edit the hstouch ini file. Interesting that the camera information is in the hstouch ini file, not the settings ini file.
Thanks for the heads up.
-Rupp
Originally posted by Rupp View Post
Are you running HS3 or HS4? So you select the X and the camera isn't removed from the list? Try shutting down HS3/4. Then edit the HSTouch.ini file and look for the sections [Cameras]
