I'm trying to register and log this with the new support portal (not receiving the register email yet), but while I wait wanted to see if there is a quick fix from the community. I just upgraded to HS4 following the upgrade guide. However, once I startup HS4, it launches a browser window with the correct IP address, but no page loads. I get the error "This Page isn't working". Any ideas?
Upgraded to HS4 and Web Page Won't Load
Here is a paste from the log
12/9/2020 3:33:02 PM HomeSeer~!~Database~!~Opening (Mode=Read Only) up HomeSeer LOG database C:\Program Files (x86)\HomeSeer HS4\Logs\HomeSeerLog.hsd
12/9/2020 3:33:02 PM HomeSeer~!~Startup~!~Loading Settings
12/9/2020 3:33:02 PM HomeSeer~!~Startup~!~Settings Loaded.
12/9/2020 3:33:02 PM HomeSeer~!~Startup~!~*************************************** *****************************************
12/9/2020 3:33:02 PM HomeSeer~!~Startup~!~ HomeSeer version 4.1.9.0 Edition: HS4 Pro Starting Now
12/9/2020 3:33:02 PM HomeSeer~!~Startup~!~Creating Class Objects...
12/9/2020 3:33:02 PM HomeSeer~!~Startup~!~COM port classes started.
12/9/2020 3:33:02 PM HomeSeer~!~Startup~!~Application interface class started.
12/9/2020 3:33:02 PM HomeSeer~!~Startup~!~Web server class started.
12/9/2020 3:33:02 PM HomeSeer~!~Startup~!~E-Mail SEND class started.
12/9/2020 3:33:02 PM HomeSeer~!~Startup~!~E-Mail RECEIVE class started.
12/9/2020 3:33:02 PM HomeSeer~!~Startup~!~Plug-In Interface class started.
12/9/2020 3:33:02 PM HomeSeer~!~Startup~!~Local voice recognition class started.
12/9/2020 3:33:02 PM HomeSeer~!~Startup~!~Loading configuration file ...
12/9/2020 3:33:02 PM HomeSeer~!~Warning~!~Unable to load devices config file, trying backup
12/9/2020 3:33:02 PM HomeSeer~!~Warning~!~Unable to load event groups config file, trying backup
12/9/2020 3:33:02 PM HomeSeer~!~Warning~!~Unable to load events config file, trying backup
12/9/2020 3:33:02 PM HomeSeer~!~Startup~!~HomeSeer version is: 4.1.9.0
12/9/2020 3:33:02 PM HomeSeer~!~Startup~!~Creating Speaker Client Interface Object...
12/9/2020 3:33:02 PM HomeSeer~!~Warning~!~This version of HomeSeer is not registered and is currently disabled
12/9/2020 3:33:02 PM HomeSeer~!~Web Server~!~Local IP address (subnet) is: 192.168.1.181 (255.255.255.0)
12/9/2020 3:33:02 PM HomeSeer~!~Web Server~!~Web Server started on port 81
12/9/2020 3:33:03 PM HomeSeer~!~Startup~!~Start automation engine...
12/9/2020 3:33:03 PM HomeSeer~!~Startup~!~Initializing Speaker Client Interface
12/9/2020 3:33:03 PM HomeSeer~!~Speech~!~Listening for remote speaker connections on port 10401
12/9/2020 3:33:03 PM HomeSeer~!~Database~!~Opening (Mode=Read/Write) up HomeSeer Energy database C:\Program Files (x86)\HomeSeer HS4\Data\Energy\Energy.hsd
12/9/2020 3:33:03 PM HomeSeer~!~Startup~!~Updater services starting...
12/9/2020 3:33:03 PM HomeSeer~!~Startup~!~Starting Find service...
12/9/2020 3:33:03 PM HomeSeer~!~Info~!~Remote plug-in API interface started on port 10400
12/9/2020 3:33:03 PM HomeSeer~!~Startup~!~Checking for available plug-ins
12/9/2020 3:33:03 PM HomeSeer~!~Startup~!~Initializing Plug-Ins
12/9/2020 3:33:03 PM HomeSeer~!~HSTouch Server~!~Server started on port 10200
12/9/2020 3:33:03 PM HomeSeer~!~Startup~!~HStouch server started, waiting for clients to connect.
It never prompted me to register my license. In HS3 there was a button above Web interface and and Startup Log that isn't there in HS4. Not sure how to correct the license issue.
I have a complete copy of the HS3 folder, so no worries there. That wouldn't have anything to do with the issue I'm seeing. I did a complete clean install in another folder (without copying or referencing any old data), and I get the same results. It should launch the web interface, but it doesn't. I tried it on another computer and got the same results.
Guest
Never mind, I figured it out. Just punch in you own IP and port number. Thanks.
That was an odd error.
