New devices.html with many GUI updates
    Team,
    Getting annoyed by the HS4 usability I decided to update the code myself.
    It's all documented on the HS4 GUI Hacks page.
    UPDATED for HS 4.1.17
    There a 2 major changes that also work fine on mobile devices.
    1. filters with 2 columns
    and an extra SAVE button
    I have not updated the categories list to 2 columns because I don't have that many categories
    Below: updated version (0.6) with bigger save buttons
    Click image for larger version  Name:	homeseer-gui-changeV2-step1-new.png Views:	68 Size:	414.1 KB ID:	1445198
    2. Device list with loc2/1
    plus the 'primary/parent' device with a different background color.
    Click image for larger version  Name:	homeseer-gui-changeV2-overview.png Views:	73 Size:	298.6 KB ID:	1441870
    3. AND MORE!
    Screenshots on the HS4 Hacks page.
    Like it? Like it!
    Suggestions? please comment!
    Its modification is very nice, and the look is fresh, clean not to mention well organized.
    I wanted to jump right in and thank you what must have been a significant amount of effort!
      Just updated the code as I found a bug (where it would not show ALL locations)
      FIX in v4: https://www.domoticaworld.com/script...-hacks-part-2/
        Thanks, I am truly enjoying your version of the device page!
          Hi DJ,
          Thanks for this. You may need to revisit your changes as it would appear the space for devicetext/devicestring is being collapsed or overlapping other columns.
          The first image is the normal devices.html and the remaining 2 are with your page. Adding the two extra columns only seems to work with short devicetext entries.
          Jon
            Originally posted by jon00 View Post
            Hi DJ,
            You are right. Guess how many devices I have with a lot of text in the device string :-) zero. And that's why I was able to generate some space for the 2 new location columns.
            If I would make it configurable (wider device-string/narrow device-controls) then other devices will 'suffer' :-)
            In the next days I will add a big-string-device and play with the different options.
            Question: what would be a good fix?
            When increasing the device-string width other columns will have to shrink: which columns?
              I suppose the only option is to make all columns adjust/fit to page size. You also have to check page size as HS4 changes layout as the page width reduces. I seem to remember 3 states Desktop then Tablet then Mobile. You can replicate that by making the browser window smaller as it switches between the 3.
              Jon
                Just posted updated code
                v5: https://www.domoticaworld.com/script...-hacks-part-2/
                Changes:
                v0.5: even/odd nr of locations now always display correctly
                v0.5: less space for last-changed, more for device-string (will this help a bit jon00 ?)
                v0.5: below filter buttons: showing nr of devices (filtered & total)
                v0.5: device count numbers bold
                  DJF3 Great idea on the two column lists. The Save button is never visible requiring one to scroll to find it.
                  The Cancel button is redundant as there is an X at the top so you might be able to get more space by removing the bottom buttons altogether.
                  One annoyance is using the check boxes then having to scroll up to the top of the screen to find the Bulk Action key. Then after executing an action the checks persist. It is a bit clunky.
                    Changes:
                    Yes, that works much better, Thanks!
                    Jon
                      In version 0.6 I have made the save buttons WIDE.
                      I've not been able to find a way to keep the bulk action key in focus when scrolling.
                        Just posted updated files for HS 4.1.14
                        https://www.domoticaworld.com/script...e-for-v4-1-14/
                          Just trying this for the first time. Excellent enhancements!
                          Not sure whether I'm doing something wrong or what...I'm not seeing colored icons in the events list. Is that feature included for 4.1.14?
                          Thanks.
                          -Wade
                            Thanks.
                            Events list - Colored Icons?? where is that mentioned?
                            DJF3 Nice work!!
                            HS4 Pro Edition 4.2.5.0 running on Lenovo ThinkCenter & Debian Linux
                            Plugins: Z-Wave (via Nortek USB stick
                            Home Assistant 2021.10.6 running on HA "Blue" ODROID-N2
                            Add-ons: Android Debug Bridge, Duck DNS, ESPHome, File Editor, Glances, HA Google Drive Backup, InfluxDB, Log Viewer, MariaDB, Mosquitto broker, NGINX SSL Proxy, Node-RED, Portainer, SSH & Web Terminal, Samba, TasmoAdmin, UniFi Controller, Visual Studio Code, WireGuard, Zigbee2mqtt, Z-Wave JS to MQTT
                            Integrations: AccuWeather, Alexa Media Player, Glances, Google Nest, HACS, HomeSeer, Insteon, IPP, Life360, Local IP, Logitech Harmony Hub, Mobile App, MQTT, My Garage, OpenWeather, Spotify, Tuya Local. Ubiquiti UniFi, Z-Wave JS
                            Insteon: 2413S Dual Band PLM
                            Zigbee: zzh! CC2652R Rev A
                            Z-Wave: RaZberry daughtercard on RPi 1B via ser2net
                              Great improvement, like it very much.
                              Perhaps an idea to make the font of the location a bit more 'bold'. The contrast with the new colored background is more pleasant. For example:
