Device User Note
    Device User Note
    I use some device user notes to edit and store some JSON data which is used by a script. This saves me writing a dedicated webpage for editing the data or manually editing an ini file for example.
    Unfortunately, in HS4, user notes no longer work it seems. The user notes are still in the devices (I can pull back the notes in the script) and I can enter a new note which is again visible in the script. However, once the user note and the device are saved, the note appears blank on the editing page if you try to edit what you have entered. Has anyone else seen this behaviour and is there any workaround?
    You can still use the old device screens to edit notes: http://192.168.1.170:84/_deviceutility.html
    tenholde
      Thank you, that works! I can at least keep things running. It would be nice however if this was fixed in the new page!
        I would recommend you report it as a bug: https://forums.homeseer.com/forum/ho...to-help-center
        Jon
          Seems like I need to set up yet another account to do that but will give it a whirl...
            It's there in HS4.
            Try open the device and click on the 'note' symbol behind the devicename.
