One-liner for device status
    I was just starting to get comfortable with HS3 and HAD to migrate to HS4 as my pi card was getting full so I was due.... for a newbie when it comes to scripting. I am trying to figure out what its the HS4 one-liner to write to the log is. Trying to catch voltage variations in my house which are triggering the generator unexpectedly... and I thought this would be simple but can't get a command that works.
    Simple event - manually run for know one-liner:
    Execute the command:
    &nhs.writelogex("Voltage", hs.Devicestatus(99),"")
    where 99 is the ID of the (child) device that contains VALUE = 123.827 and STATUS = 123.827 Volts. I know that hs.Devicestatus(99) is the wrong command. What should it be? I got &nhs.writelogex("Voltage", "This should be a var","") to work, but figuring out how to populate the second text element with the dynamic voltage in the device is stomping me.
    Thanks for the patience for the "new" old guys as usual.
    The status is not a direct property like value and string. HS has provided substitution variables for event actions. I do not know if they would work with script one-liner or not. I suspect not, but you could try &nhs.writelogex("Voltage",$$DSR99):,"")
      If you want the numeric value, try hs.DeviceValue(dvRef).
        More importantly, if you want to track data over a long term why not just use one of the data collection and charting plug-ins that are available for free, like Jon00 Charting? I've got several charts and databases tracking changes in temp, humidity, or anything else that changes over time. The database is setup to automatically log the time-value pairs whenever a device value changes. One can then easily plot these variations against other things that change in the environment over time.
          Tried that - although I’m struggling with what the little sad icon is supposed to be. I’m getting a compile/runtime error with $$DSR:99:
            That worked thanks - interestingly it only pickups the integer part of the number, not the decimal places which seem to be there. not a big deal as I’m trying to capture big variations of a volt or more, but technically intriguing why it chops off the decimals...
              And why didn’t I think of going to Jon’s stuff which has saved my hide so many times... Thanks. Will try that - maybe from a windows machine, getting the device over from the Pi with Jon’s HSgateway so I’m not putting more stuff on the already overloaded pi.
                Legacy from the original HS. You can get the number from the value property of the device, but if you want to use the script command DeviceValue then it returns the integer as was done in the original HS.
                Substitution variable is $$DSR colon (99) colon. I do not think it will work as substitution variables were not discussed in the scripting help guide.
