Newbie to HomeSeer, have just installed HS4 on Linux (Debian 10.7). Everything seems to boot up ok but I am seeing the following error in the log...
Compiling script Startup.vb: Could not load type of field 'vbnc.Scanner:m_PeekedChars' (21) due to: Could not resolve type with token 010000d1 from typeref (expected class 'System.Collections.Generic.Queue`1' in assembly 'mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=XXXXXX') assembly:mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=XXXXXX type:System.Collections.Generic.Queue`1 membernull) at vbnc.Main.Main (System.String[] CmdArgs) [0x00016] in :0 Failed compilation took 00:00:00.0337530
(PublicKeyToken redacted, just in case it needs to be redacted)
Is this error something I should be concerned about?
Mike
Mike
