Damn Dropdown ...
    Damn Dropdown ...
    need a button to release the drop down menu on the main screen
    I want to see the results, not the criteria, this screen can take over the whole screen only showing an inch of devices..
    or.. am I doing something wrong ( naw.... )
    Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro ๐Ÿ˜Ž
    Try using hxxp://ipofhomeseer/deviceutility.
    - Pete
    Auto mator
    Fanless Intelยฎ Celeron N3160 SoC 8Gb
      as usual... great, is there a place to change the default ??
        Do yourself a favor and install Jon00Links... besides being able to create custom widgets and menus at the top, it automatically creates a menu of all the legacy HS3 menus.
          off to download, Jon, here I come ( again )
            Seriously, I don't know why they just don't hire him. They probably can't afford him
              must have made a typo...
Name:	Jon00 startup.JPG
                  It looks like you have quite a few categories/criteria selected. I recall seeing some posts from people who felt they had to have every floor/room/category checked to see their devices. If you fall into that group, try removing all those criteria (click the X next to them).
                  I usually just use one search criteria if I need to narrow my devices. At most I might use 2 or 3.
                  HS4 Pro on Shuttle NC10U, Win10; Z-NET
                  Number of Devices: 449
                  Number of Events: 210
                  Plug-Ins: Arduino, BLLock, DirecTv, EasyTrigger, Honeywell WiFi Thermostat, MeiHarmonyHub, PHLocation2, Pushover 3P, UltraM1G3, WeatherXML, Worx Landroid, Z-Wave
                  External applications: Homebridge-homeseer, Geofency, EgiGeoZone.
                    As the error states you are missing a )
                    It should have False,False)
                    Sent from my SM-G973F using Tapatalk
                    Zwave = Z-Stick, 3xHSM100๏ฟฝ 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
                    Scripts =
                    Various
                      Same here. I've changed my Loc1 and Loc2 fields to "Room" and "Device-type", just using those two I can quickly see the devices I'm interested in, whether they are real or virtual. I don't think I've ever had a need for Category now that I've got my naming convention nailed down.
ID:	1452961 still errors, even with the control char inserted Click image for larger version
                          Since the log shows two TTS "Speak" Web server is blah, blah and the next line is the hs.runscriptfunc call I'd say the space between runscriptfunc and the "(" is likely the culprit of the error, or Jon00LinksHS4.vben file itself. Do the links show up in the web interface that this script adds?
                            The issue is that you have entered the hs.Runscriptfunc incorrectly.
                            Replace what you have with:
                            hs.Runscriptfunc ("Jon00LinksHS4.vben","Main","" ,False ,False)
                            Jon
                              Thanks for the reach out.. yep several typos' now fixed off to configure
                              Geary
