Just updated to 4.1.12.0 and startup errors show as below. The install appeared to go correctly. I can supply more logs but didnt want to supply everything as it may be one area is needed and there is a lot of data that could be uploaded.
I'm about to go find out how many areas are affected.
Disk and all other software (NON HS - not that there is much at present) appears to be working. I will be running further checks though.
Has anyone else seen this and know how to fix it?
Many thanks,
Mark
12/02/2021 01:48:20 HomeSeer~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=
12/02/2021 01:48:22 HomeSeer~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=
12/02/2021 01:48:25 HomeSeer~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=
12/02/2021 01:48:26 Legacy-Plugin~!~RFXCOM Error: ~!~41 (StartIO) receiver 1 has no com interface configured!
12/02/2021 01:48:27 HomeSeer~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=
12/02/2021 01:48:30 HomeSeer~!~Error~!~SQL Exception adding record(s) to the LOG database(0): database disk image is malformeddatabase disk image is malformed, Code=11 SQL=
Many thanks,
Mark
