I've had the same issue with the last 2 HS4 updates when automatically triggered at startup (Setup>General>Other Settings>Check for Update at Startup. Before reporting as a bug I'd like to know if others are seeing similar behavior or if I'm doing something wrong.
I didn't make notes of the exact prompt verbiage, but this is the gist of it:
After starting HS4, it checks for and finds an available update. It asks whether I want to install, and I allow it. Meanwhile HS4 continues to start up, including plugins. The update downloads, begins installing, and then stops with a prompt listing all running processes that need to be closed before continuing. First option is let HS4 close the processes and attempt to restart them after upgrade. Second option is proceed with installation, requiring reboot afterwards. On choosing the first option, HS4 seemingly attempts to close the processes and a few seconds later (10 seconds maybe?) installation stops again. The prompt lists the running processes again (fewer than the first time, some have stopped) and says to ensure they're stopped/closed before continuing. Going to Task Manager at this point I can see the processes are gradually being closed, it just hasn't finished. After maybe 15-30 seconds all HS processes have disappeared from Task Manager. Clicking continue will then allow installation to proceed successfully.
In summary, it seems the installer doesn't allow enough time for the HS processes to be closed before trying to proceed, leading to a somewhat vague/confusing instruction to close them before continuing--yet they continue to close automatically. The process works, but it's not as simple and intuitive as most software upgrades. Is anyone else seeing this?
Thanks.
Thanks.
