Script error in HS4 but not HS3
    I am getting this error on a script that ran fine in HS3 and runs fine in HS4 except that it generates this error in the log:
    Running script(2) &if hs.devicevalueex(1337)>hs.devicevalueex(1351) then hs.SetDeviceValueByRef 1351,hs.devicevalueex(1337),True, init error: Syntax error
    I have tried various variation on the syntax with no luck. I have been ignoring this for several versions because the script is working but it is starting to get annoying now.
    Thoughts?
    The immediate script command in HS4 is still buggy.
    You can get around the issue using the following:
    &nhs.version: if hs.devicevalueex(1337)>hs.devicevalueex(1351) then hs.SetDeviceValueByRef (1351,hs.devicevalueex(1337),True)
    Jon
      Thank you jon00. Much appreciated.
