HS4 - Zwave with Dual Zwave Controllers - not listed as device
    It appears that HS4 does not recognize Dual Zwave Devices (Minoston Smart Plug (2 channel) Model MP20z) and other Manufactured Dual zWave Devices.
    When you try to "ADD DEVICE" only the Root is shown for both devices BUT the a & b Device Switch ON/OFF is not.
    The net result, after my HS4 Upgrade from HS3, many of my Zwave Devices won't work!
    Doug
    I had same issue and finally just used my Hubitat hub added to HS with the plugin all good. I've had issues with HS connecting to other devices like the Zooz double plug/relay etc. and used the Hubitat hub for those too. I don't think the HST spends much time making sure that some of the newer Zwave devices will work. You can tell this by how often they update the Zwave plugin which is never.
