I'm running Node-RED on an AWS EC-2 instance. Is there a way to reference my HomeSeer (I'm running HS4 on a HomeTroller Zee S2) as a server in the Node-RED HS Device node?
Node-RED on AWS
Originally posted by david.i.tanzer@gmail.com View PostI'm running Node-RED on an AWS EC-2 instance. Is there a way to reference my HomeSeer (I'm running HS4 on a HomeTroller Zee S2) as a server in the Node-RED HS Device node?
At your own risk try : https:// {your username}:{password}@myhs2.homeseer.com:{port of your HomeSeer System}
And in HomeSeer custom settings https:// {the access address of your AWS Node-RED}:1880/homeseer/webhook
No guaranties if this will work but...you're the one doing the hacking!
Else, you may need to contact this guy here : https://www.youtube.com/watch?v=n_1wX7kKx7k (Unrelated but he knows his stuff)
Eman.
It should look like in the image below but I have not tested.... We did that trick with a remote speaker client on a Laptop and it worked!. But what I think it only works on plug-ins
You may need to contact spud or Michael McSharry to secure your mqtt nodes from AWS back to HomeSeer.
There is also this : https://flows.nodered.org/node/node-...ib-aws-iot-hub (Which should be local on a Raspberry pi)
How to start right here : https://nodered.org/docs/getting-started/raspberrypi
EmanTinkerLand : Life's Choices,"No One Size Fits All"
Originally posted by david.i.tanzer@gmail.com View PostSo, port forwarding DOES work! I simply created a dummy port (I used 1880 because that's what Node-RED uses) and forwarded it on to the internal IP of my Zee S2 at port 80. Bingo! It works!
Try this guy again : https://www.youtube.com/watch?v=80vIin4xGp8
Eman.TinkerLand : Life's Choices,"No One Size Fits All"
Eman, thanks for your suggestions. I don't believe using myhs2.homeseer.com will work for Node-RED--I think it needs to talk directly to an IP. And the Raspberry Pi documentation is for installing it on a local device, in this case, of course, a Rapsberry Pi. In my case, I'm running it on an AWS EC2 box. As well, I'm using the HomeSeer-provided Node-RED node: https://flows.nodered.org/node/node-...ntrib-homeseer which I don't believe uses MQTT.
This is very cool, though. Changes to my HomeSeer devices immediately reflect in Node-RED flows, and the Node-RED sourced control of my HomeSeer network is very fast!
I'd be considering a VPN or at the very least locking down port 1880 to only accept traffic from AWS IP's...HS4 Pro Edition 4.2.5.0 running on Lenovo ThinkCenter & Debian Linux
Plugins: Z-Wave (via Nortek USB stick
Home Assistant 2021.10.6 running on HA "Blue" ODROID-N2
Add-ons: Android Debug Bridge, Duck DNS, ESPHome, File Editor, Glances, HA Google Drive Backup, InfluxDB, Log Viewer, MariaDB, Mosquitto broker, NGINX SSL Proxy, Node-RED, Portainer, SSH & Web Terminal, Samba, TasmoAdmin, UniFi Controller, Visual Studio Code, WireGuard, Zigbee2mqtt, Z-Wave JS to MQTT
Integrations: AccuWeather, Alexa Media Player, Glances, Google Nest, HACS, HomeSeer, Insteon, IPP, Life360, Local IP, Logitech Harmony Hub, Mobile App, MQTT, My Garage, OpenWeather, Spotify, Tuya Local. Ubiquiti UniFi, Z-Wave JS
Insteon: 2413S Dual Band PLM
Zigbee: zzh! CC2652R Rev A
Z-Wave: RaZberry daughtercard on RPi 1B via ser2net
Originally posted by david.i.tanzer@gmail.com View PostEman, thanks for your suggestions. I don't believe using myhs2.homeseer.com will work for Node-RED--I think it needs to talk directly to an IP. And the Raspberry Pi documentation is for installing it on a local device, in this case, of course, a Rapsberry Pi. In my case, I'm running it on an AWS EC2 box. As well, I'm using the HomeSeer-provided Node-RED node: https://flows.nodered.org/node/node-...ntrib-homeseer which I don't believe uses MQTT.
I run 2 locally (one on ioBroker and the stand alone which also has an mqtt instance reason being I can't run the Node-RED NEEO nodes on the ioBroker instance and the same goes for the ioBroker Nodes, they come bandied with the server- As for mqtt nodes, they add more juice to the mix , they add to the alchemy...
Originally posted by Eman View Post
You could also have 2 or more (but 2 are enough in my case) instances of Node-RED (Local and the AWS EC2 box) Depending on what you are running, you can have the remote one enable when you are away from home but have the local one deal with the in-house automations (your ball)
Eman.
John
- Likes 1
Originally posted by John245 View Post
Why would people like to life on the edge and and an additional point of failure?
John
What he didn't explain about is what he was using the AWS EC2 box for (Why not install Node-RED locally and avoid running it remotely)
Unless I missed something?... https://aws.amazon.com/ec2/instance-types/- Now like you can see in the above posts everything diverted into security issues
- I explained myself, what I do with my 2 local instances...I guess that clears everything...
So if he is OK with his instance, all he has to deal with is this : https:// {the access address of your AWS Node-RED}:1880/homeseer/webhook
