nothing is triggered event system seems to be down
    Last hs4 4.1.18.0 release version here.
    Anyone ever got this? This is pretty alarming.
    Homeseer process is using 100% cpu, nothing have triggered since one hour, and nothing works right now, except if I manually control an hs device. The hs event system seems to be down somehow.
    Message
    7/19/2021 22:00:58
    HomeSeer
    Device Control
    Device: JowiHue JowiHue Office lamp (On/Off/Dim) to On (255) by/from: CAPI Control Handler
    7/19/2021 22:00:57
    HomeSeer
    Device Control
    Device: JowiHue JowiHue Office lamp (On/Off/Dim) to Off (0) by/from: CAPI Control Handler
    7/19/2021 21:48:29
    HomeSeer
    Device Control
    Device: Virtual Virtual Bathroom Group to On (100) by/from: CAPI Control Handler
    7/19/2021 21:03:39
    HomeSeer
    Device Control
    Device: JowiHue JowiHue Kitchen Group (On/Off/Dim) to Off (0) by/from: CAPI Control Handler
    7/19/2021 21:03:39
    HomeSeer
    Event
    Event Trigger "kitchen group (Nested) Kitchen ceiling"
    7/19/2021 21:03:39
    HomeSeer
    Event
    Event Trigger "kitchen group Kitchen (Nested)"
    7/19/2021 21:03:39
    HomeSeer
    Device Control
    Device: Virtual Virtual Kitchen group to Off (0)
    7/19/2021 21:03:39
    HomeSeer
    Event
    Event Trigger "Kitchen Sensors If NO MOTION in Kitchen set LIGHT TO OFF"
    7/19/2021 20:54:02
    HomeSeer
    Event
    Event Trigger "Hallway Sensors (Nested) Set hallway from 20 to off after sunset if motion etc"
    7/19/2021 20:54:02
    HomeSeer
    Event
    Deleting event after run: "Delayed Events (Nested) Set hallway from 20 to off after sunset if motion etc (Delayed Event)"
    7/19/2021 20:54:02
    HomeSeer
    Event
    Event Trigger "Delayed Events (Nested) Set hallway from 20 to off after sunset if motion etc (Delayed Event)"
    7/19/2021 20:52:01
    HomeSeer
    Event
    Delayed Trigger Event Removed: (Nested) Set hallway from 20 to off after sunset if motion etc (Delayed Event)
    7/19/2021 20:52:01
    HomeSeer
    Event
    Event Trigger "Hallway Sensors Set hallway to 21 after sunset if motion etc.(nested)"
    Nothing in syslog
    I won't send this to hs support since I know I won't get much help.
    I am afraid I don't have an answer for the problem at hand but I feel your sentiment about not even bothering reporting the problem. I just did log into the support site using one of some 4 different usernames/password to use HS (site to log problems/suggestions, site to purchase stuff, myHS, plugin pwd, etc). Turns out most of my 4 pages of bugs and recommendations were closed. I didn't bother checking if HS actually did anything but the couple of closed entried were simply closed. No fix or improvement. Oh well...
      That might be related to an MQTT plug-in even though I don't see anything mqtt in that log so I reserve judgement...
      Tip : If it turns out to be the problem, make sure to use an external Broker for your mqtt to avoid lock-ups or every time you do maintenance you make sure the client is connected before you leave the scene.
      Eman.
        Since I have never seen this problem, its hard for me to troubleshoot. I really need you to disable all your plugins and then enable them one at a time to see which one is causing the issue. I will mention that there is a setting in setup labeled "Enabled Event System". If this is unchecked, events will not run. I suspect this is not your issue, but I have seen it trip up users in the past.
          Understood.
          I should have asked this question first . Do you think there was a change between hs4 v4.1.7.0 , and 4.1.8.0 that could explain the OP?
          I have deleted some non essential post on this topic.
            I do not see any changes from .17 to .18 that would affect the events. If you restart HS does it work for a while then stop? Or does it never process any events? Go to the control panel off the tools menu and enable event debug mode by entering the following:
            hs.debugmode=2
            Now check the log and see if there are some debug messages related to the event logging, maybe create an event that should trigger at a specific time.
              Maybe i have found the culprit.
              I saw3 days ago that the zwave coreplugin was also a 100 cpu usage. So I deleted the zwave ui plugin since I do not use it.
              in my mind the hs issue I explained above comes from zwave … and the interaction of the two cause aomething bad on hs4 side.
              Since 3 days I am on hs4 v4.2.0.0, And I have not seen the op issue . Need to test longer but maybe that new info can help you to troubleshoot to problem. rjh
