Hi
I haven't configured new devices for a while, but need a couple of new virtual devices to control dim levels of lighting throughout the day. This has been a breeze earlier, but now I can't seem to set the desired control value from a range on the virtual device. It seems that the device only carries single value controls labels and range Prefix/Suffix. Not the actual value. I have tried everything I can think of, but can't figure this one out. Please help.
I also noticed that compared to a previous virtual device I made, the " Include Values" under Range Control is missing/removed. See before/after pictures;
I can compensate for this by making single value controls within the range for the virtual device, but this is very impractical and time-consuming.
This is my setup:
And with single value compensation for not beeing able to select a value within the range:
So to sum up;
1. Why can't I select a value within a range from an event anymore? (First pic)
2. Is there some new different way of including values that I haven't picked up on? Where is the "Include Values" option? (Second/Third pic)
Spec:
Win 10
HS 4.1.18.0
G
This is my setup:
So to sum up;
Spec:
Win 10
HS 4.1.18.0
G
