I'm trying to write a script that will upload a file from homeseer to my NAS (Synology). I created a user specifically for this FTP and confirmed the credentials work.
I keep getting the following error:
FTP Error(0): In FTP Login: Could not resolve the host name or IP address to a system IP Address
What am I doing wrong?
This is my code:
Public Sub Main(ByVal Parms As Object) Dim ftpOutput As String Dim host As String Dim user As String Dim password As String Dim command As String Dim rfile As String Dim lfile As String Dim path As String host = "192.168.1.177" user = "xxxxxxxx" password = "xxxxxxxxxx" command = "put" lfile = "C:\Program Files (x86)\HomeSeer HS4\html\backups\8_1_2021-3_1_20.zip" rfile = "8_1_2021-3_1_20.zip" path = "\Network Devices\HomeSeerHub\Hub Backups\" ftpOutput = hs.FTP(host, user, password, command, path, lfile, rfile) hs.WriteLog("HS4_FTPTransfer Error: ", ftpOutput) End Sub
