I upgraded to 4.2.0.0 Windows
all seem fine for a few days then my Z-Wave devices no longer.
I tried a "Test Node Connectivity on a Network" in the Z-Wave Controller and got the following.
My battery powered z-wave window and door sensors all still work
Any ideas out there?
Obtaining a list of nodes to be contacted...
34 nodes will be contacted, the following nodes will be skipped: 1 16 17 21 23 24 25 26 31 34 37 39 40 41 43 45 50 52 53 56 58 59 61 62 65 66 67 68 71 72 74 75 77 78 80 83 84 86 89 92 93 94 95 96 99 100 103 105 106 109 112 119 143 169 170 172 174 176 177 178 184 192 199 200 202 203 206 208 217 222 223 227
Node 19 (Ground Hall Main hall fibaro 2*1.5KW) did not respond.
Node 20 (Ground Study TKB plug in) did not respond.
Node 29 (First Bed 2 Cupboard (repeater)) did not respond.
Node 36 (Ground Dining Main Light (dimmer)) did not respond.
Node 38 (Node 38 Z-Wave Sigma Switch) did not respond.
Node 42 (Ground Study Eurotronic TRV) did not respond.
Node 57 (Ground Hall Lamp) did not respond.
Node 60 (Ground Kitchen Z1, Z2 - Fibaro 2*1.5KW) did not respond.
Node 63 (Ground Living Sub plug in) did not respond.
Node 73 (Ground Study Zipato siren) did not respond.
Node 97 (Ground Kitchen MCO floor thermostat) did not respond.
Node 98 (First Bed 1 Lamp) did not respond.
Node 102 (Ground Bathroom Fibaro Switch) did not respond.
Node 104 (Ground Garage Fibaro light right) did not respond.
Node 107 (Ground Cloakroom Cloakroom fibaro 2*1.5KW) did not respond.
Node 108 (Ground Utility Utility, Outside - fibaro 2*1.5KW) did not respond.
Node 113 (Ground Kitchen Bar, plinth - fibaro 2*1.5KW (D1)) did not respond.
Node 114 (Ground Kitchen Fibaro kitchen above, under R (D7)) did not respond.
Node 116 (Ground Garage Fibaro light left) did not respond.
Node 125 (Heating Function Heating control) did not respond.
Node 126 (Ground Hall Everspring Siren) did not respond.
Node 127 (First Landing Vision Sec Siren) did not respond.
Node 133 (Ground Back Outside living Zipato bulb) did not respond.
Node 134 (Ground Kitchen Outside, under L - Fibaro 2*1.5KW) did not respond.
Node 135 (Ground Back Outside fitness Zipato RGB bulb) did not respond.
Node 147 (Ground Front Zipato 1 bulb) did not respond.
Node 155 (Ground Living Fibaro living lights) did not respond.
Node 181 (Ground Bathroom Eurotronic TRV) did not respond.
Node 209 (Ground Study Fibaro Switch) did not respond.
Node 210 (Ground Fitness Fibaro light switch) did not respond.
Node 211 (Ground Back Fibaro Switch) did not respond.
Node 219 (First Bed 2 Fibaro Switch) did not respond.
Node 220 (Ground Living Eurotronic TRV) did not respond.
Node 221 (Ground Fitness Eurotronic TRV) did not respond.
Finished!
Finished!
