HomeTroller Zee S2 Slave from HS4
    Hi,
    I'm new here. We are using HS4 pro with Aeotec Z-Stick for Z-wave as of now.
    We also have a HomeTroller Zee S2, and we are planning to use the Hometroller as a slave to extend out signal to basement.
    Zwave extender devices is out of the picture.
    Is there a way to make this HomeTroller as a slave from our HS4 pro so we only use one system? are there any documentation about this?
    Hope someone can help us and we appreciate your kindness.
    Thank you.
    The HomeTroller Zee S2 is just a Raspberry Pi...Just remove the SD card and keep it in a safe place and get another SD Card and Pete , randy or zwolfpack will help you build an extra network interface : https://forums.homeseer.com/forum/ho...n-raspberry-pi
    Eman.
      Here is the original post using an RPi2.
      You will need to use Linux command line which is mostly copy and paste type stuff.
      HS3 Linux with Remote Z-Wave Interface Setup Guide
      It is the same for HS4.
      - Pete
      Auto mator
      Fanless IntelĀ® Celeron N3160 SoC 8Gb
