if device has it's value set to.... the event fires twice
    I am running HS4 Pro Edition 4.1.18.0 (Windows) and i have a problem with events.
    If i make an event with: if devices changes to.. it works and the event fires 1 time but..
    if i make an event with: if device has it's value set to.... the event fires twice..
    why is this?
    Can you take a screenshot of the event and post it here?
      For what it's worth, I've seen this in HS3 too. I couldn't figure it out, so I just worked around it.
        I have a lot of events that use "set to" and "set or changed" and I've not seen this. I'd look at the device itself instead of the event. Is it possible the device value is toggling or bouncing a few times? A workaround for this is to not allow the event to re-trigger within X seconds. Not a fix for sure, but a workaround until you can figure out why it's happening.
          ofcourse
            It only happens if i use: has device value set, if i use change to it works as it should
              I do think the press of the button might be send twice actually within the same second on Zwave. I see this also happening for my plugin sometime (catching that internally). Easiest solution is working around it by setting the events option to not rerun for 1 or 2 seconds. Might be less hassle then trying to get the Zwave plugin to catch that situation.
              -- Wim
                Thank you, i added the "can not retrigger in 1 sec" and it world now. Still no idea if this i a bug or a feature.
                  You should be able identify the source of the issue by looking at the log. Make sure commands from the HS device are logged. If you see back to back commands issued from the wall controller, it is at fault. If there is only one, then it is within the system. I’ve not used the Aeotec wall scene controller, but I never had that issue with my Aeotec Minimotes, my Remotec or Hank remotes or with HS scene control switches, dimmers or fan controls.
                  The “Event Cannot Re-Run for:” setting will eliminate the bounce, no matter the reason.
                    checked again, wallmote is working as it should
                    node 1 is controller (ofcourse)
                    node 199 greenwave module
                    node 219 aeotec wallmote
                    Click image for larger version  Name:	sniffer.JPG Views:	0 Size:	65.7 KB ID:	1493468
                      Here a screenshot. top part is another wallcontroller.
                        well, it seems it's a aeotec wallcontroller thing, i tried a walli controller and that ones works fine.
                          akatar,
                          What application did you use in the above screenshots?
                          Roger D
                            Originally posted by Roger D View Post
                            akatar,
                            Roger D
                            it's zsniffer, it listenens and reports all zwave traffic (everything, so also you neighbours)
                              if you have problems you can see what happens and where things (wich device) go wrong.
