HS4 Start up folder HS4 will not load on system restart
    I never had this issue with HS3, hopefully someone has a work around.
    I've added HS4 short cut and hs4.exe to shell:startup folder. Still will not start on a restart.
    Anyone have command script or registry update suggestion ?
    Hometroller S6 Pro
    I'm not sure where the posts are, but have you added the HS4 startup to the Windows Task Scheduler so that it starts HS4 at user login for the HS4 machine?
    I had the same problem and added a task in the task scheduler (It's touchy but works) that starts HS3 upon the reboot of windows and the login of the user that runs the HS3 instance.
      I was just about to try using task scheduler. I tried REGEDIT but didn't make any difference.
        I did everything I could think of, only the procedure for the Task Scheduler worked for me for some reason, and that is on HS3.
          That did the trick! We were on the same page! Thanks
            Hometroller S6 Pro
            Did you follow the upgrade guide?
            https://docs.homeseer.com/display/HS4/Windows+and+S6
            -Rupp
              Cool! 😁
                Hi Rupp, I didn't catch that one, I must have overlooked it. The task scheduler did work. I did the Windows and HS upgrade instructions.
