How to trigger event every 1st of the month?
    Hi!
    I am looking for a way to reset a device value every 1st day of the month. Recurring trigger should have had a "every month" or "annual" option.
    Is there already a way to do this?
    Join
    Originally posted by Join View Post
    Hi!
    Join
    Yes, see the below event. The first "IF" is called your trigger and I'm guessing the best trigger will be a specific time of day that you would like for that event to trigger. The second is called an event condition which is where you will be able to select your specific date that you want the event to trigger on. In this case, the first day of every month of every year.
    HS4 4.2.6.0 &HSTouch Designer 3.0.80
    Plugin's:
    weatherXML, Jon00 Alexa Helper, Network Monitor, MyQ, Z-Wave
      You have to use the second condition to get what you are after. Make the first a specific time, so that event knows what time to run, then set the second. Choose the first day of any month, then check the boxes for Any Month and any Year. You want something similar to the image below for the conditions:
      Karl S
      HS4Pro on Windows 10
      1070 Devices
      56 Z-Wave Nodes
      104 Events
        https://forums.homeseer.com/forum/ho...of-month-event
          Thanks guys!
          It all makes sense now.
          I think it will work.
          Join
