Yearly event trigger, is this me or a bug?
    Hello,
    Trying to set an event to run yearly, like an anniversary, every year same day and month, like this.
    However, after saving, going back into the condition, the Any Year checkbox comes back unchecked. Rechecking the box and validating again yields the same results. That kinda tells me it's gonna run on the specific date only.
    I have the same behaviour with Any Month and Any Day check boxes. Not that I get the Any Day one, just setting a time would do the trick since you must set a time before setting a date. 🤔
    For the record. I'm running HS4 Pro Edition 4.2.0.5 beta (Windows).
    So, what am I not getting here?
    It works for me. I pick a date, select any year and save the Condition. It is correct. I open it back up and it is correct. HS 4.2.0.8. I wonder if it is specific to your date format.
    Click image for larger version  Name:	14CB8784-86A7-4B6E-89B7-96ADD2944D84.jpeg Views:	0 Size:	30.0 KB ID:	1496781
    Click image for larger version  Name:	7E691AA5-266A-46E8-B378-34F30EAAE4F5.jpeg Views:	0 Size:	24.5 KB ID:	1496780
      I'm seeing the same behaviour as zguy...
      Save it...
      Re-open it...
      HS4 Pro Edition 4.2.0.8 Beta running on Lenovo ThinkCenter & Debian Linux
      Plugins: Z-Wave, SDJHealth
      Z-Wave via Nortek USB stick
      Home Assistant 2021.9.6 running on HA "Blue" ODROID-N2
      Add-ons: Android Debug Bridge, Duck DNS, ESPHome, File Editor, Glances, HA Google Drive Backup, InfluxDB, Log Viewer, MariaDB, Mosquitto broker, NGINX SSL Proxy, Node-RED, Portainer, SSH & Web Terminal, Samba, TasmoAdmin, UniFi Controller, Visual Studio Code, WireGuard, Zigbee2mqtt, Z-Wave JS to MQTT
      Integrations: AccuWeather, Alexa Media Player, Glances, HACS, HomeSeer, Insteon, IPP, Life360, Local IP, Logitech Harmony Hub, Mobile App, MQTT, Nest, OpenWeather, Spotify, Ubiquiti UniFi, Z-Wave JS
      Insteon: 2413S Dual Band PLM
      Zigbee: zzh! CC2652R Rev A
      Z-Wave: RaZberry daughtercard on RPi 1B via ser2net
        Might be specific to date format.
          Date format! Definitely a possibility.
          Standard date format in Canada is YYYY-MM-DD. This is what I'm using. dbrunt is using that too but randy is using MM/DD/YYYY.
          I'm not seeing a date format in HS4 so assuming it uses OS date format, I changed the OS date to US MM/DD/YYYY. Restarted HS and TADA!
          I get
          and editing the condition, the Any Year checkbox remains checked. That should work.
          This is so basic for God's sake. 😡 Been using HS since back to HS2, never had that issue. And I'm not inclined at all to use that US format.
          Going back to the event, US date is still there and checked. Add the same date, check the Any Year box and save:
          Result editing the condition:
          So, there is a date format bug. How do we get that fixed?
            See here for HS4 bug reporting: https://forums.homeseer.com/forum/hs...to-help-center
            Whilst you wait, you may be interested in this: https://forums.homeseer.com/forum/3r...r-3-homeseer-4
            Jon
              Thanks jon00
              Originally posted by jon00 View Post
              For reference, Issue HSCS-9263 has been created in HS service desk portal.
              That will indeed address my need. Contribution sent.
              Any way to make this work with a 14 days rollover instead of yearly?
                Many thanks.
                I'll take a look but I don't think that would be easy. It was written to calculate from a specific date only.
                Jon
                  Actually, our standard is DD-MM-YYYY. YYYY-MM-DD is International and USA is MM-DD-YYYY.
                    Thanks jon00
                    OK, I've taken a look and I can add a recurring roll-over period. Should be ready shortly. Check the main thread for updates:
                    Jon
                      Right. In Québec though lots of people use YYYY-MM-DD.
                        That's cool! Will do. Thanks.
                          I often use YYYY-MM-DD myself as it is unambiguous. When you see 02-04-2021 is it Feb 4th or Apr 2?
                            Indeed. Add to that 24h time as in 00:00 for midnight and 23:59 for the last minute of the day.
                              I always use YYYY-MM-DD as it is the best way to ensure correct sorting in a spreadsheet even if the field is not formatted as a date.
