Virtual Device Has No Control/Status
    I was trying to create a virtual device and I noticed that the Control/Status column is missing. If you open another device created in the past it shows this column. See pic. This is the same in edge or firefox.
    Click image for larger version  Name:	pic1.png Views:	0 Size:	19.1 KB ID:	1497086
    Click on the edit icon and you will be able to add
      Still does not show up.
        Click image for larger version  Name:	pic3.png Views:	0 Size:	21.5 KB ID:	1497091
        Try Row value “1” and Column 2 and 1
        I sse you already did that
          I also don't have the Control/Status column for any HS4 created Virtual Devices. They are present on the HS3 devices.
          RJ_Make On YouTube
            Same here except the devices created in a earlier version of HS4 has that column available. I am on 4.0.2.8 which does not.
              Lots of issues with devices not showing including in events etc with 4.2.0.8. Either roll back or wait until Rich fixes these issues. Check the main thread on this: https://forums.homeseer.com/forum/hs...8-is-available
              Jon
                Thanks Jon00. I probably should copy my original post and put it in the thread you mentioned. That is where it belongs. Thanks
                THIS HAS BEEN MOVED TO LINK ABOVE
                  Not reporting this in the new thread but just testing work around using H3 Legacy Device Management, via Jon00's links. The page does have rendering issuing with the latest release, and potentially earlier but the virtual device created works.
