Turn on a light for x minutes (then turn off)
    Is there a way to create an event that turns on a Z-Wave device for a time interval, then turns it off? For example, simulate an occupancy sensor light switch, or turn on a space heater for 20 minutes then turn it off, etc? I'm trying to avoid using external things like IFTTT or NodeRed, but I am open to suggestions.
    I tried to create an even to turn on a HS wall switch, but I didn't see a "for this time interval" or 'wait this long then turn off" scenario.
    There are a lot of ways to accomplish this with events and I'm sure you will get several options here. One option I use is to turn off if there has been no motion for X minutes/seconds. See event below.
    Plugin's:
      Simplest way to do it would be to turn the light on then add a second "then" step of wait for X number of minutes. Then add a 3rd "then " step to turn light off.
        Have your event turn the light on, then turn it off "after a delay of xx minutes". That way you can have another event cancel the delayed action should you choose. Look for the HS3/HS4 Event clinic for more options.
          This looks perfect. Thanks!
