First of all, I like the HS3 version of the log file because the formatting on that page make it easier and cleaner to copy portions of the log display from the screen and paste it into Excel for further manipulation and analysis. The HS4 version just isn't as clean and easy to use. I know you can export the log to a text file, but then you have to locate the file on your PC and then import it into Excel. The screen grab and paste is a much easier option.
Second issue is that the HS4 log file is broken. If you filter the log using "From" or "Type" or even "Search Log", the paging of the log doesn't work properly. Page 1 of the log does not follow the time stamp from page 0, and page 2 does not follow page 1, etc. Portion of the log are either duplicated or skipped between pages. The HS3 log filtering works as expected.
