As discussed in the JowiHue forum, I need to restart my PC after it has restarted because my router takes a bit of time to be ready.
So I downloaded BLShutdown but can't get it to work. I simply took the example in the help file and put it into a script file. I have no idea how to work with anything having to do with scripts.
I created a virtual device that is either off or on to indicate that the second restart occurred.
I also created a re-start event that waits x minutes after restart and then tries to execute the BLShutdown script.
All to no avail. Can someone help me configure the script so I don't get errors please.
Sub Main()
hs.PluginFunction("BLShutdown", "", "Shutdown", New Object(){2})
End Sub
I tried this within a re-start.vb file and as a direct command to no avail.
Since I need to restart the PC as well, the parameter is a "4" not a "2" as is shown in the help file, but either way I have no idea how to configure.
Sub Main()
End Sub
