When running HomeSeer as a service, the service runs under the account LOCALSYSTEM. This account has it's own regional settings. If you are using custom date/time formats you will need to modify these settings on the LOCALSYSTEM account. To do this you can copy your current settings to the LOCALSYSTEM account. See the screen shots below for the procedure. Thanks go to Jon00 for providing these screen shots.
Using custom regional settings when running HomeSeer as a service
This is a sticky topic.
Originally posted by rjh View PostWhen running HomeSeer as a service, the service runs under the account LOCALSYSTEM. This account has it's own regional settings. If you are using custom date/time formats you will need to modify these settings on the LOCALSYSTEM account. To do this you can copy your current settings to the LOCALSYSTEM account. See the screen shots below for the procedure. Thanks go to Jon00 for providing these screen shots.
HomeSeer Version: HS4 Pro Edition 4.2.16.0
Operating System: Microsoft Windows 10 Pro - Desktop Z-Wave via Z-Net
Zigbee via RaspBee on RPi 3b+
WiFi via Internal APs.
Enabled Plug-Ins
AK Weather 4.0.5.1,AmbientWeather 3.0.1.9,Big6 3.34.0.0,BLBackup 2.0.63.0,BLGData 3.0.55.0,BLLock 3.0.39.0,BLUPS 2.0.26.0,Device History 3.3.1.0,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,HSBuddy 3.30.1003.1,JowiHue 4.0.8.4,LG ThinQ 4.0.24.0,rnbWeather 4.4.0.0,SDJ-Health 3.1.1.2,TPLinkSmartHome4 2022.12.30.0,UltraCID3 3.0.6681.34300,Z-Wave 3.0.11.0 Z-Wave Hub Z-Net, Zigbee Hub: ZigBee on RPi 3+, WiFi on Internal AP.
I can't replicate the issue, but when I "Quoted" the original post there was the text of the post AND the raw JSON instead of the images. When I saved what I had written, even though the JSON was visible as part of the quoted text and was between {Quote} and {/Quote}, it disappeared. The screenshots still didn't show. Everything appears normal, now...HomeSeer Version: HS4 Pro Edition 4.2.16.0
Enabled Plug-Ins
Originally posted by ewkearns View PostI can't replicate the issue, but when I "Quoted" the original post there was the text of the post AND the raw JSON instead of the images. When I saved what I had written, even though the JSON was visible as part of the quoted text and was between {Quote} and {/Quote}, it disappeared. The screenshots still didn't show. Everything appears normal, now...
Steve
I simply copied and pasted the images into the post, and I could see them but when I tried another browser I could not. I think that is the issue. If you add them as attachments, they show. I will see if we can fix that. I checked the URLs in my original post and they did point to the images. Might be a permissions thing.
Originally posted by SteveMSJ View Post
Your not going mad, when I originally looked, just before your original post, they weren't showing for me either. Now they are. This seems to be a common issue on these forums.
Steve
Yeah, it looked like the links to the images were there. There were three lines of JSON code that showed up as literals in the quote, but only once. IOW the JSON wasn't interpreted by whatever should have done so. I was using Firefox 95.0.2.
I would suggest that anyone else experiencing this should quote the offending post and if the JSON lines appear then submit a screenshot for examination.HomeSeer Version: HS4 Pro Edition 4.2.16.0
Enabled Plug-Ins
- Likes 1
