In my never ending quest to finding the problem for my HS4 reliability/out of memory issues I reset my Z-wave database/devices and started from scratch.
I have a Jasco/GE 26933 which is a motion sensor and dimmer in 1. When I added it to the network initially, it worked perfectly. Now for some reason every time I add it, it seems to get the child device of the Motion Sensor wrong and I end up with a "Notification" child device that just always reads "OK".
I don't know why it added correctly initially and won't now, everything has been completely reset. It's almost like it's detecting it as a different template/switch without the motion.
The switch is NODE6. I'm using a SmartStick+.
I see the following error in the logs, not sure what it implies.
"Notification Report from node 6 for type Home Security received, but the corresponding device Node ID cannot be found. (2, Type=7)"
This is the result of a rescan.
Loading network information from your Z-Wave interface...
Done.
Synchronizing network information against HomeSeer devices...
Getting Z-Wave node list for network C5415019...
Found 5 Z-Wave nodes
Syncing Z-Wave nodes with device list...
Synchronize nodes finished. Number of device nodes to be created/added = 0
Node: 2 Supports Class(es): ZWAVEPLUS_INFO, ASSOCIATION, MULTI_INSTANCE_ASSOCIATION, ASSOCIATION_GRP_INFO_V2, TRANSPORT_SERVICE, VERSION, MANUFACTURER_SPECIFIC_V2, DEVICE_RESET_LOCALLY, INDICATOR, POWERLEVEL, SUPERVISION, FIRMWARE_UPDATE_MD
Node 2 is Z-Wave version: Lib: 7.11 App: 1.3
Node 2 is a Z-Wave Plus node. Retrieving ZWPlus Info...
Node: 3 Supports Class(es): ZWAVEPLUS_INFO, VERSION, ASSOCIATION, ASSOCIATION_GRP_INFO_V2, TRANSPORT_SERVICE, MANUFACTURER_SPECIFIC_V2, DEVICE_RESET_LOCALLY, POWERLEVEL, SWITCH_MULTILEVEL_V3, SWITCH_ALL, CONFIGURATION, CENTRAL_SCENE_V2, SCENE_ACTUATOR_CONF, SCENE_ACTIVATION, SUPERVISION, FIRMWARE_UPDATE_MD
Node: 3 Controls Class(es): CENTRAL_SCENE_V2
Node 3 is Z-Wave version: Lib: 4.61 App: 5.14
Node 3 is a Z-Wave Plus node. Retrieving ZWPlus Info...
Node: 4 Supports Class(es): ZWAVEPLUS_INFO, VERSION, ASSOCIATION, ASSOCIATION_GRP_INFO_V2, TRANSPORT_SERVICE, MANUFACTURER_SPECIFIC_V2, DEVICE_RESET_LOCALLY, POWERLEVEL, SWITCH_MULTILEVEL_V3, SWITCH_ALL, CONFIGURATION, CENTRAL_SCENE_V2, SCENE_ACTUATOR_CONF, SCENE_ACTIVATION, SUPERVISION, FIRMWARE_UPDATE_MD
Node: 4 Controls Class(es): CENTRAL_SCENE_V2
Node 4 is Z-Wave version: Lib: 4.61 App: 5.14
Node 4 is a Z-Wave Plus node. Retrieving ZWPlus Info...
Node: 6 Supports Class(es): ZWAVEPLUS_INFO, MANUFACTURER_SPECIFIC_V2, DEVICE_RESET_LOCALLY, POWERLEVEL, SWITCH_MULTILEVEL_V3, SWITCH_ALL, SCENE_ACTIVATION, SCENE_ACTUATOR_CONF, CONFIGURATION, VERSION, NOTIFICATION_V6, MULTI_CHANNEL_V3, MULTI_INSTANCE_ASSOCIATION, ASSOCIATION, ASSOCIATION_GRP_INFO_V2, FIRMWARE_UPDATE_MD, CRC_16_ENCAP
Node 6 is Z-Wave version: Lib: 4.34 App: 5.32
Node 6 is a Z-Wave Plus node. Retrieving ZWPlus Info...
Warning: Node 4 did not respond to the Switch Multilevel Supported Get request.
Warning: Node 6 did not respond to the Notification Supported request.
2 out of 2 Child devices of node 3 were created successfully.
Enabling instant status for Z-Wave device Lighting Front Door Root (4)
2 out of 2 Child devices of node 4 were created successfully.
SmartStick+: Adding association for Z-Wave device Lighting Guest Bathroom Root (Node 6, Group 1, Endpoint 1) to HomeSeer
SmartStick+: Adding association for Z-Wave device Lighting Guest Bathroom Root (Node 6, Group 2, Endpoint 2) to HomeSeer
2 out of 2 Child devices of node 6 were created successfully.
Finished with Z-Wave device synchronization.
Done.
