As a longtime Insteon user, I'm a bit behind on the other technologies like Z-Wave and Zigbee and how they work. At this point i'm just researching my options for moving forward with a new/different technology. Not necessarily looking to forklift what i already have in place and is still working well. But I've got a few questions that I haven't found concise answers to so far.
- I think that Z-Wave and Zigbee both need hubs or interfaces to work. Are these hubs standalone devices that HS communicates with like a protocol converter of sorts? Or are they a communication accessory for the HS machine? Is it more like an insteon hub or a PLM?
- Are there different styles of these hubs where some are direct attached to the HS machine, vs a device that sits elsewhere on the network? My HS server is virtualized. I don't have the ability to attach serial or USB devices directly to it. I need an IP addressable interface device.
- Do you have to use the built in logic and automation of the hubs, or can you just use it as a technology interface and do all the automation in HS?
- Do the wall switches perform well in steel wall boxes? Here in the Chicago area, all of our electrical boxes and conduit are steel. Most of my faceplates are steel as well. Insteon works well. I'm skeptical about RF-only solutions.
- Do Z-Wave and Zigbee have an equivalent to insteon links where you can have virtual 3 way switches and each switch stays in sync? If so, how do you configure this?
- Which brand makes products that are the most similar to insteon dimmer switches? Mostly with regard to look and feel. Simple decora style paddle, and an LED indicator for dim level. I don't want to have different style buttons and such around the house.
