Originally posted by TC1
View Post
Thinking of Moving from HS3 to HS4
About 9 months ago I made the attempt to migrate from HS3 to HS4. At that time I also decided I would migrate HS3 from Windows to Linux (all virtualized) first and then upgrade.
This did not go well and I ended up rolling everything back to Windows HS3 and sitting tight.
What were the issues?- Unfortunately Mono on Linux does not do ASP well and switching to ASPX resulted in huge performance issues (clicking a window would take 30-60 seconds to update). These were not HS pages, but other pages like Jon00 HTML. No attempt at pre-compiling, etc. really fixed the issue. Near as I can tell this is a known Mono issue.
- I'm heavily using Jon00 "plugins" and some of these are subtly broken (such as Jon00 Network). Other plugins like Arduino had their serial port support (RS232) broken. I tried workarounds and different software but in the end things were not working and events depending upon them no longer reliable. I did verify before I did the upgrade that the plugins I use where good for Linux.
- Coming from the information dense HS3 UI, HS4 is a struggle - feel like I have to scroll and click through everything to "see" what was a glance in HS3. God help you if you decide to filter on a bunch of things - a huge chunk of UI to show what filters are active blocks you from seeing much of the actual data requiring more scrolling.
- My HS4 Z-wave migration was a disaster, all HS devices got disconnected from their Z-wave nodes and even with a backup I had to laboriously reconnect everything - that was not fun.
I have spent the past few days trying to work around the UI - it is much better than 9 months ago but honestly the menu bar is super clunky (Devices, Events, Cameras, etc). I have installed Jon00 Links to try and work around things adding custom widgets pointing to custom HTML pages and that certainly helps me get to where I want to go faster. After spending a few days with this it's my feeling that the internal event/state machine handling is super solid but the UI is a work in progress which unfortunately still has a ways to go before it gets to the maturity of HS3 UI.- I am more heavily leaning on Jon00 HTML to construct an information dense UI - the biggest issue is no dynamic updates to the data like in the main UI. I also leverage Jon00 Links to make the HS3 pages available.
- Odd UI things like a left over for example: Plugins->Legacy Z-Wave that points to a ton of 404 links. Not sure if that is some Jon00 mistake (not trying to cast blame) or it was from the legacy Z-Wave prior to upgrade. Not sure if I should hunt it down in the html pages or if there if I should be uninstalling something.
- The missing HS UI pieces are annoying - trying to fix the broken images require you to edit the device status/graphic ranges. Unfortunately directory selection is no longer supported so yet another Jon00 plugin to the rescue.
- Unfortunately all of this work around does not integrate with the menu bar particularly well - I wish I could customize that menubar to better align to how I use HS.
If you are waiting on HS4 my experience is the backend part of Homeseer is very robust at this point. The UI is ok and, for me, I can make it work with enough 3rd party tools.
-Jeff
- Likes 2
