I have been battling with this for a couple of weeks now. For no apparent reason, all events stop working. Manually triggering a event does not result in any action either.
Everything else still works.
I can control Zwave devices, status updates, also Nest, Rfxcom, Shelly, Rachio, Tasker, all work. Devices update and can be controlled.
I thought a update from 4.2.11.0 to 4.2.12.0 and subsequently 4.2.13.0 was the probelm.
So I uninstalled HS4, kept data, and reinstalled 4.2.11.0. A couple of days after starting HS4 events stopped again. I then updated to 4.2.13.0 again. And again, after a couple of days events stopped working. Most of the time after a couple of hours, everything is running again. There is nothing in the log, no errors. ll I can see in the log at the time is there is no events showing.
This is causing major problems, so I need to try to find the problem, and at the same time need more information so I can try and file a bug report, and hope for some help from HS...
I thought of triggering a automatic restart when this happens, but as no events will run, that is not an option...
Not sure what else I can do to narrow down the problem
Date/time=18/06/2022 11:12:36 GMT Summer Time
Version=HS4 Pro Edition 4.2.13.0 (Windows)
License=Registered
MyHS Subscription=Basic
MyHS Subscription Backup Interval=No Backup
MyHS Subscription Max Cameras=1
Confguration File=C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.json
In Virtual Machine=No MFG: lenovo
Antivirus=Windows Defender
OS=Microsoft Windows 10 Pro - Work Station
OS Version=10.0.19043
Uptime=0 Days 0 Hours 31 Minutes 53 Seconds
User/Access=xxx (Admin)
Device Count=1224
Event Count=658
Last Event Ran=System : Multi Watts display, Ran at 18/06/2022 11:12:38
# of unique event scripts=90
Processor:=AMD64 Family 23 Model 24 Stepping 1 at 1.30 GHz
Modules/Threads=136 Modules, 200 Threads
Available Threads=1023
System Load=264 Processes, 31% Load
Free/Total Memory=2.05 GBytes / 5.93 GBytes (35% free)
Free/Total Virtual Memory=4.86 GBytes / 12.44 GBytes (39% free)
HomeSeer Memory Used=151 Mbytes
Plugin Memory Used=24 EXE Plug-Ins using 766 Mbytes
Plugins Installed=AK Shelly 3.0.0.97,BLGData 3.0.55.0,BLLAN 2.0.45.0,BLShutdown 1.0.6.0,BLStat 2.0.87.0,Blue-Iris 3.1.3.33206,drhsIpPlugIn 0.0.0.25,EasyTrigger 3.0.0.74,Global Cache Pro 5.0.0.59,HSBuddy 3.28.1222.5,JowiHue 4.0.7.3,Kodi 3.0.1.14,Linktap 3.0.1.0,mcsMQTT 5.24.10.0,mcsShelly 5.24.10.0,Neato Botvac 4.0.9.1,Nest 3.0.0.34,NetCAM 3.0.0.14,PHLocation2 3.0.0.64,Pushover 3P 0.0.0.54,Rachio 4.0.2.0,RFXCOM 30.0.0.41,Sonos 3.1.0.57,Tasker Plugin 3.0.4.9,UltraLog3 3.0.6644.26753,Z-Wave 3.0.10.0
License=Registered
Device Count=1224
Event Count=658
